Posted on Feb 23, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How do I load the software? When I put the disc in there are no instructions on how to load it into my computer
Jose Ma DM.
Level 3:
  • Master 540 Answers
  • Posted on Feb 23, 2011
Jose Ma DM.
Master
Level 3:
Answers
540
Questions
0
Helped
177139
Points
1776
There should be a setup.exe or install.bat file located usually at the root folder, if installation doesn't start automatically, maybe you have disabled auto play for your CD/DVD drive, to enable it, please go to control panel, look for Auto Play feature and select the action to take according to your disk type (data,media).
Anonymous
Level 3:
  • Master 526 Answers
Anonymous
Master
Level 3:
Answers
526
Questions
Helped
104396
Points
1770
If the disc does not autoplay, then open it manually the file.. go to my computer>then double click cd drive>then broswe the files..double click on the exe.files if you want to install the software on your pc..
goodluck and may this helps your problem...
pls rate..thanks
I have the Digitizer Jr. software and it will not load onto my computer
You need to stop using Vista as Microsoft has not supported it since 2014. OK to use Vista for a while after 2014 because Windows Update still gave security updates for other Windows products (Word, Works, etc.). But now, Windows Update for Vista will not work anymore for anything. At least switch to Windows 7 as Microsoft will probably support it until 2020.
I do not have a disk to install to get startedand i do not know how to manually start it on the computer.
If you do not have a disc for your computer, you can purchase one at any computer electronics retail store in your area. It is a must have to start the System Software loading process for the Windows Operating System to be installed on a computer.
You can use a USB stick to load Windows but you have to have drivers installed and a good copy of the Operating System you are installing. It would be easier to just go and get one and then insert it and follow the onscreen instructions with the load. This way you will have a legal copy, your own disc and no future problems of lacking a good disc in case of a crash. Just a suggestion! Thanks for using FixYa! John
Need help with set up on SMPK8099. When loading software on my computer from the disk I got a warning that further installation will damage my computer which uses XP. I disconnected the player, ejected...
I got the same thing on my computer when I put the disc in. Really I didnt even need to load it in my computer. I use MP3 rocket pro and load all my songs syncin them with windows media player. I also did not see the battery icon flashing but I left it plugged into the computer and let it charge a while. When you turn the power on ant the top of the mp3 player turn power on and press power button on the keypad on front surface of mp3 player. It is the bottom button at 6 oclock try that and see what happens. Make sure to hold button in for a couple seconds.
I have Print Perfect Platinum and cannot open the file to load the program as there is no setup on the first disc. Help Help
HI,
You can try putting the disc in your drive, go to my computer ,click on the drive you have the disc in. This should open the disc for you to load. Good Luck. ( By the way I am not a computer wiz,)
2answers
How do i instal my cam on computer
to install web cam to your computer you must put the usb to the usb port then insert the driver cd to the cd driver and press install...click and wait until it will finish install then after that you can use your cam..
regards..
3helpful
Belkin F5D700 installation software disc
u'll have all the drivers for this adapter in this link. download the correct drivers depending on the version of the adapter which can be found on the adapter itself. http://en-us-support.belkin.com/app/answers/detail/a_id/303/kw/f5d7000/r_id/166
Microsoft FSX will not load on my new Vista PC
Hello hshames,
The game requires Windows XP SP2, or Vista..So that should not be the problem.
First install the latest version of Direct X which you can download FREE HERE.
Below is a small summary of what may be causing your installation problems.
This seems to be a problem some users are having.It seems to be either software related (other software not the actual software on the FSX disc itself), or hardware related (DVD drive not reading the disc properly).
To try solve this issue, follow these steps in order. If the problem is solved after step 1 (for example) you do not need to follow the instructions following that step. if not solved, move to the next step in the chain.
1. Some DVD readers can take up to 2 minutes to detect disc #2 (for reasons unknown). If the disc appears not to be detecting, just leave the computer for a few minutes and come back and check. Some users have reported that the disc #2 finally detects and installs correctly several minutes after inserting the DVD into the drive.
2. Manually browse the Disc #2 file contents in either Windows Explorer, or by accessing the DVD through the "My Computer" option and check the files on Disc#2 are actually different to those on Disc #1.
3. If you have the hard drive space available, copy the contents of both DVDs to a temporary folder on your hard drive, and install the product from the hard drive copies.
4. Read this Microsoft Tech article and follow instructions > http://support.microsoft.com/kb/290301
After trying the above suggestions, please post back with the status of your problem and any new info so I can be of further help.
Thank you for choosing Fixya!
Will the mini setup disc work in my MACBOOK?
maybe, look in the instruction manual and see if the software is compatable with mac either way it will not mess up your computer (unless it is slot loading) in which case yes it will mess up your computer
Need to know how to burn to disc
1. Put a blank disc in the drive.
2. Run the software on your computer designed for burning discs. If you cant find one, download a trial version of nero, www.nero.com.
3. Follow the step by step instructions in the software.
4. You have a freshly burned disc.
OR
You can take the disc, douse it with lighter fluid, and apply match. :c)
Top Copenhagen Audio Players & Recorders Experts
 Grubhead
Grubhead
SmartAviator
SmartAviator
Are you a Copenhagen Audio Player and Recorder Expert? Answer questions, earn points and help others
