Computers & Internet Logo
Posted on Feb 19, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have reinstalled Windows XP on a Sony Vaio Desktop with the details below. I have downloaded and installed the sound drivers as listed for this model. All shows OK on the device manager but I have no sound. Tested with another set of speakers with the same result. What else should I try? Thanks, David System Information ------------------ Time of this report: 2/19/2011, 12:06:41 Machine name: HOME Operating System: Windows XP Home Edition (5.1, Build 2600) Service Pack 3 (2600.xpsp_sp3_gdr.101209-1647) Language: English (Regional Setting: English) System Manufacturer: Sony Corporation System Model: PCV-RX560(UC) BIOS: Award Medallion BIOS v6.0 Processor: Intel(R) Pentium(R) 4 CPU 1700MHz Memory: 256MB RAM Page File: 158MB used, 459MB available Windows Dir: C:\WINDOWS DirectX Version: DirectX 9.0c (4.09.0000.0904) DX Setup Parameters: Not found DxDiag Version: 5.03.2600.5512 32bit Unicode ------------ DxDiag Notes ------------ DirectX Files Tab: No problems found. Display Tab 1: No problems found. Sound Tab 1: No problems found. Music Tab: No problems found. Input Tab: No problems found. Network Tab: No problems found. -------------------- DirectX Debug Levels -------------------- Direct3D: 0/4 (n/a) DirectDraw: 0/4 (retail) DirectInput: 0/5 (n/a) DirectMusic: 0/5 (n/a) DirectPlay: 0/9 (retail) DirectSound: 0/5 (retail) DirectShow: 0/6 (retail) --------------- Display Devices --------------- Card name: NVIDIA RIVA TNT2 Model 64/Model 64 Pro (Microsoft Corporation) Manufacturer: NVIDIA Chip type: RIVA TNT2 Model 64/Model 64 Pro DAC type: Integrated RAMDAC Device Key: Enum\PCI\VEN_10DE&DEV_002D&SUBSYS_40031043&REV_15 Display Memory: 32.0 MB Current Mode: 1024 x 768 (32 bit) (75Hz) Monitor: Plug and Play Monitor Monitor Max Res: 1600,1200 Driver Name: nv4_disp.dll Driver Version: 6.14.0010.5673 (English) DDI Version: 7 Driver Attributes: Final Retail Driver Date/Size: 4/14/2008 00:42:04, 4274816 bytes WHQL Logo'd: Yes WHQL Date Stamp: n/a VDD: n/a Mini VDD: nv4_mini.sys Mini VDD Date: 4/13/2008 17:04:32, 1897408 bytes Device Identifier: {D7B71E3E-436D-11CF-DA65-0960B4C2CB35} Vendor ID: 0x10DE Device ID: 0x002D SubSys ID: 0x40031043 Revision ID: 0x0015 Revision ID: 0x0015 Video Accel: ModeMPEG2_A ModeMPEG2_B ModeMPEG2_C ModeMPEG2_D Deinterlace Caps: n/a Registry: OK DDraw Status: Enabled D3D Status: Enabled AGP Status: Enabled DDraw Test Result: Not run D3D7 Test Result: Not run D3D8 Test Result: Not run D3D9 Test Result: Not run ------------- Sound Devices ------------- Description: SoundMAX Digital Audio Default Sound Playback: Yes Default Voice Playback: Yes Hardware ID: PCI\VEN_8086&DEV_2445&SUBSYS_80E4104D&REV_12 Manufacturer ID: 1 Product ID: 100 Type: WDM Driver Name: smwdm.sys Driver Version: 5.12.0001.3030 (English) Driver Attributes: Final Retail WHQL Logo'd: Yes Date and Size: 7/25/2001 15:40:30, 438200 bytes Other Files: Driver Provider: Analog Devices HW Accel Level: Full Cap Flags: 0xB5B Min/Max Sample Rate: 8000, 48000 Static/Strm HW Mix Bufs: 1, 0 Static/Strm HW 3D Bufs: 0, 0 HW Memory: 0 Voice Management: No EAX(tm) 2.0 Listen/Src: No, No I3DL2(tm) Listen/Src: No, No Sensaura(tm) ZoomFX(tm): No Registry: OK Sound Test Result: Not run --------------------- Sound Capture Devices --------------------- Description: SoundMAX Digital Audio Default Sound Capture: Yes Default Voice Capture: Yes Driver Name: smwdm.sys Driver Version: 5.12.0001.3030 (English) Driver Attributes: Final Retail Date and Size: 7/25/2001 15:40:30, 438200 bytes Cap Flags: 0x41 Format Flags: 0xCCC ----------- DirectMusic ----------- DLS Path: C:\WINDOWS\SYSTEM32\drivers\GM.DLS DLS Version: 1.00.0016.0002 Acceleration: n/a Ports: Microsoft Synthesizer, Software (Not Kernel Mode), Output, DLS, Internal, Default Port SoundMAX Digital Audio, Software (Kernel Mode), Output, DLS, Internal Microsoft MIDI Mapper [Emulated], Hardware (Not Kernel Mode), Output, No DLS, Internal Microsoft GS Wavetable SW Synth [Emulated], Hardware (Not Kernel Mode), Output, No DLS, Internal Registry: OK Test Result: Not run ------------------- DirectInput Devices ------------------- Device Name: Mouse Attached: 1 Controller ID: n/a Vendor/Product ID: n/a FF Driver: n/a Device Name: Keyboard Attached: 1 Controller ID: n/a Vendor/Product ID: n/a FF Driver: n/a Poll w/ Interrupt: No Registry: OK ----------- USB Devices ----------- + USB Root Hub | Vendor/Product ID: 0x8086, 0x2442 | Matching Device ID: usb\root_hub | Service: usbhub | Driver: usbhub.sys, 4/14/2008 07:00:00, 59520 bytes | Driver: usbd.sys, 4/14/2008 07:00:00, 4736 bytes ---------------- Gameport Devices ---------------- ------------ PS/2 Devices ------------ + Standard 101/102-Key or Microsoft Natural PS/2 Keyboard | Matching Device ID: *pnp0303 | Service: i8042prt | Driver: i8042prt.sys, 4/14/2008 07:00:00, 52480 bytes | Driver: kbdclass.sys, 4/14/2008 07:00:00, 24576 bytes | + Terminal Server Keyboard Driver | Matching Device ID: root\rdp_kbd | Upper Filters: kbdclass | Service: TermDD | Driver: termdd.sys, 4/14/2008 05:43:22, 40840 bytes | Driver: kbdclass.sys, 4/14/2008 07:00:00, 24576 bytes | + PS/2 Compatible Mouse | Matching Device ID: *pnp0f13 | Service: i8042prt | Driver: i8042prt.sys, 4/14/2008 07:00:00, 52480 bytes | Driver: mouclass.sys, 4/14/2008 07:00:00, 23040 bytes | + Terminal Server Mouse Driver | Matching Device ID: root\rdp_mou | Upper Filters: mouclass | Service: TermDD | Driver: termdd.sys, 4/14/2008 05:43:22, 40840 bytes
gaurav hariyani
Level 2:
New Friend:
  • Expert 124 Answers
  • Posted on Feb 19, 2011
gaurav hariyani
Expert
Level 2:
New Friend:
Answers
124
Questions
0
Helped
19123
Points
328
Try installing realtek sound driver it must work.
2helpful
VGN TX650P FN keys and AV buttons are not working after reinstalling windows and drivers.
i,
It depends how you reinstalled the OS in the computer, was it using the recovery discs or retail XP disc. Using recovery discs if you are installing, everything should work fine. This scenario may occur if you have used a retail OS disc to reinstall the OS.
Anyways try the below mentioned troubleshooting steps:
Install the Original Video Driver from the below link:
http://esupport.sony.com/US/perl/swu-download.pl?mdl=VGNTX650PB&upd_id=2149&os_id=7
After this install Origial VAIO Event Sevices:
http://esupport.sony.com/US/perl/swu-download.pl?mdl=VGNTX690P&upd_id=1975&os_id=7
Then, install VAIO Event Service Update.
http://esupport.sony.com/US/perl/swu-download.pl?mdl=VGNTX650PB&upd_id=2287&os_id=7
At last, install the AV Mode Utility app:
http://esupport.sony.com/US/perl/swu-download.pl?mdl=VGNTX650PB&upd_id=2040&os_id=7
Install the drivers in the same order, this should work. VAIO Event Services take cares about the FN keys, after installing all these drivers, restart the computer and check if the VAIO Event Service is running at the startup.
Thanks!!!!
I had to reinstall windows xp because i had a system32 error, but now when i try to watch a video i get no sound.
XP does not have all the drivers you need. Download the Sony drivers and install them
http://esupport.sony.com/US/perl/swu-list.pl?mdl=VGCRB60G
If this answers your question, I'd appreciate 4 thumbs. I do this for fun and do not get paid.
Jim
I reinstalled the windows on my vaio computer and now i dont have sound. and its because i dont have the cd to install multimedia audio controller, does any one know where can i get it? i have a sony vaio...
This is Sony eSupport and the Drivers and Downloads page for the Sony Vaio PCV-RS320,
http://esupport.sony.com/US/perl/swu-list.pl?mdl=PCVRS320
Click on Audio (Sound) 2 files
You want the Original - ADI SoundMAX Audio Device Driver
Altec Lansing Sound On Sony Vaio Not Working
Are you running Windows XP?
I recently had a customer with a similar problem on an XP desktop; I tried all sorts of fixes before finding the answer in an online forum - it was a problem with the 'Software Enumerator' see the link below and look for a post by 'Jurekos'
http://www.techspot.com/vb/all/windows/t-34101-The-driver-has-been-enabled-but-has-not-been-started.html
Or follow the summarised steps below:
- FIRSTLY CREATE A RECOVERY POINT IN CASE IT DOESN'T WORK AND YOU NEED TO UNDO CHANGES -
1. Check if PnP SW Enumerator is installed on your machine (Device Manager / System devices) - it should be listed there!
2. If it is not there then we will probably solve it!
3. Locate "machine.inf" on your OS, copy it somewhere and modify it as follows:
(find "ExcludeFromSelect=*" and remove the line or simply exclude it from processing by adding a ";" at the beginning)
4. Check the "machine.inf" file for location where SWENUM should be located (mine was reading: SWENUM.CoInstallers.CopyFiles = 11 ; %windir%\System32)
5. Find "swenum.sys" file on your XP installation CD (mine was in DRIVER.CAB) and copy it to the proper location (I am not sure if it is necessary but worked for me) You could also copy this file from someone else's Working copy of Windows XP if you don't have your installation CD
6. Go to Control Panel /Add Hardware and follow the wizard towards manual selection of device to be added
7. Select Add System device
8. Select Have disk
9. Navigate to changed machine.inf
10. from the list select standard devices (in the left list) and "Plug and Play Software Enumerator" in the right list
11. Finish the installation
If it still does not work reinstall the audio adapters' drivers
Post a reply if you don't understand any of the steps listed and I'll try to explain in more detail
Good Luck - John
2answers
No sound devices on my sony vaio VGN-CR322H laptop
Pl check the whether all driver from OEM have been installed including MB and try to reinstall the driver it should work fine. or reinstall the SP2 for win XP. then install the OEM driver again, this should work, else there might be hardware problem.
2answers
Where to get the recovery disk for SONY VAIO PCV-RS210 desktop computer
1(888)476-6972
san diago rrc
16550 via esterillo
building 5
door two
san diego california 92127
Sony Vaio sound...
Adam,
The sony VAIO Pcv-j200 only runs with Windows 2000, windows Me and windows xp. The current operating system Vista on your computer right now will work but some of the features of it may not. The link below shows all the drivers for your unit for diffent operating systems (not vista). What you can try to do is to download the audio driver for windows xp
http://esupport.sony.com/US/perl/swu-list.pl?mdl=PCVJ200&LOC=3
2answers
No sound on my sony vaio pcv-rs210
do u have the installed drivers?
if not, please check for them on the sony website.
Grand Canyon Tech
Grand Canyon Tech
