I just bought ddr universe 3 with the konami dance pad and the connector is circular.. i have looked everywhere on the xbox for a plug in but no good and i looked to see if there was an adapter to change it so i could use the usb ports but there isn't anything! thanks for the help
me too. i get this problem . i have a wii dance pad that has a gamecube connector , and i guess the DDR doesn't detect it as a dance pad , but as a gamecube controller . so think , you can't hold the nunchuck and the gamecube controller at the same time . so i guess we need a wireless dance pad for the nunchuck to work as well .
If you cant connect in it is probably because you need to sync it. Take off the battery cover for the pad. Now there should be a tiny red button in front of the wii console next to the sd card slots. Press for 2 seconds. now look in the battery compartment for the dance pad. there should be a similar button. press for 2 seconds. now your pad should work as the controller.
Some extra peripherals are not compatible with the new, slimmer 360, as it contains a different motherboard and other various changes. Also, see if there is an update required for the game, which would potentially allow the system to recognize your game pad.
not sure on what cord looks like but there is a port if xbox standing up its on the bottom in a door if thats not there is a USB port on the back of the box
I had same problem..if u have a dance pad with foam inserts....take out the insert and try to start up without them....the problem we had is one of the inserts was putting pressure on one of the buttons preventing xbox from reading pad...if u don't have inserts one of your buttons is sticking...give it a shake and try again....we fixed ours by simply rearranging the inserts...hope this was helpful
