As what i understand you have a failing HDD came from an old unit and trying to repair or reinstall O.S.? was your testing equip ment is the same as the harddrive you tried to replace and check. if it so. tried to replace the data cable of HDD you are using. and if you have another extra power supply try to test it with differrent PSU
SOURCE: Intel D845EPI/D845GVSR MB problem
sound like a bad memory issue. Try a with new tested memory module. Had this issue many times....
SOURCE: Intel dg31pr motherboad not booting.
Unhook everything except power and your monitor. Put one stick of memory in and attempt to boot. Post here with results, what power supply you're using, what memory, and what processor.
SOURCE: pc stuck in start up loop
Ram and Power supply are the main cause of your problem with this motherboard by replacing these one at the time could fix it
SOURCE: Intel DG45ID motherboard bricked
Here you maybe should not set the manual setting to 800 mghz.
Use the default setting as you can save and reboot it.
There may be a problem with the way the bios sees the memory. Also examine your manual carefully for indications of how the memory needs to be installed.
Some boards require two or more modules to be installed, and will not run correctly with out the modules required installed. Some of these boards will not allow mixing anything except exact sets. That is to say each module must be the same. Some boards are far more tolerant of kinds and makes of modules.
With out the memory, you will not have anything to run on.
So, I would suggest to let the bios set what it sees.
http://www.google.com/search?hl=en&q=Intel+DG45ID+pdf&btnG=Search&aq=f&oq=&aqi=
"Four 240-pin Double Data Rate 2 (DDR2) SDRAM Dual Inline Memory Module
(DIMM) connectors with gold-plated contacts
• Support for:
. Non-ECC, 1.8 V, DDR2 800/667 MHz memory
. Serial Presence Detect (SPD) memory only
. Unbuffered, non-registered single- or double-sided DIMMs (except double-sided
DIMMs with x16 organization)
. Memory configurations listed below:
• Up to 2.0 GB utilizing 256 Mb technology
• Up to 4.0 GB utilizing 512 Mb or 1 Gb technology
• Up to 8.0 GB utilizing 1 Gb technology
• A minimum of 512 MB of total memory is required"
"NOTE
To be fully compliant with all applicable Intel ® SDRAM memory specifications, the
board should be populated with DIMMs that support the Serial Presence Detect (SPD)
data structure. If your memory modules do not support SPD, you will see a
notification to this effect on the screen at power up. The BIOS will attempt to
configure the memory controller for normal operation."
So, the memory is dependent on the configuration. It appears that this board requires 4 modules at once to be installed, depends on the amount of memory per module as well.
Be careful about flashing the bios. By doing that you can ruin the bios and make the computer completely unusable until you get and install a new bios module, if you do not pick the exact correct flash version.
SOURCE: Gateway E3600 (Intel D845PT MB) won't boot after MS Update
This error comes when your motherbord not read properly harddrive.
for that first reconnect both connection to harddisk.Power cable and ide or sata cable.
Change SATA or IDE cable then check.
Pull cmos cell from motherbord for 10 minutes so all settings are factory defaults.
Then when you power up the computer press F1 or F2 or "del" key then you can see bios screen.
Make sure hardddrive detect in bios.
Set first boot device as harddrive.
Then check.
Let me know if you need further assistance.
Thanks.
