Basically you don't need a CD if you want to change the password or put a password on the network all you need to do is to access the Wireless Settings Page of the Router and put or change the Network Key. To access your router you need a working computer connected to the router then open a Browser then type 192.168.0.1. the Username is admin and the password is blank. Go the the Wireless Settings Page and under Wireless Security Mode you can change the Security Mode to either WEP, WPA or WPA2 then input your desired password.
you should not need a CD to use the router - Routers do NOT need drivers.
All the CD would do is set up the router - which you can do manually
The product manual is available here http://www.dlink.com/products/?tab=3&pid=WBR-1310&rev=WBR-1310
goto the setup section where it explains how to setupthe router manually
setup cds u dont need . . . ok so to get it to work . . . first of all is it for ur house or a work . . . i can only help for ur house . . . and work but idk if u want it for work , . . . anyways u plug it in and u put a cable to it and plug the cable into a wall . . . . and if u already have a router with a cable . . . just plug the little cord into the dlink and the other side into ur other router . . . . and it should work o-__-o urs hopefully -ELI
Go the router setup page, 192.168.0.1, type admin as the user name and password as the password (default, if you have changed these use your login info).
Then on the wireless page change the SSID (router name).
You can also add a security key on this page.
Click on this link or copy and paste the complete link into your browser. If I could be of further assistance, let me know. If this helps or solves the issue, please rate it. Thanks, Joe
As an initial info try to do a hard reset on the unit, this process will restore the system into a original settings. you can find the reset switch on either on the left of right sight of your router.
or
you may visit this SITE to recover again your current password without erasing or removing the current settings made.
Type 192.168.0.1 (you can type the router address if you have changed) and enter on browser's addressbar. Router's interface will appear. Click on SETUP and Click on the WIRELESS SETTINGS at left side. on the page you will see the option of WIRELESS SECURITY by drop down menu you can choose the Security mode that you wish. here is the link for the emulator http://support.dlink.com/emulators/wbr1310_revB/wireless.htm
Please post your question if you need further assistance Good Luck
DO NOT KNOW WHERE PASS WORD ON ROUTER IS
