Heating & Cooling Logo
Posted on Jan 19, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Split system turns off after 35 minutes. Vanes close but operation green light blinks four times. By pressing on/off switch on remote - green light stops blinking. Press on/off switch again, system starts up & runs for about 35 minutes - over & over & over . . HELP !!! Thank you - Phil
R Subramaniyam Iyer
Level 3:
  • Master 2,133 Answers
  • Posted on Jan 19, 2011
R Subramaniyam Iyer
Master
Level 3:
Answers
2133
Questions
Helped
953468
Points
6173
Out door compressor getting over heated. Check freon pressure. May be short of gas. If fan motor less rpm, replace capacitor. If condenser dust blocked,m clean it.
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Apr 01, 2012
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
1085
Points
Ii have wansa gold series when i start ac so after 2 mint ac off and green light contenew blinking help plz
How to fix my inverter split type aircon with an EC display, pls help me
Press the on/off but on for two to four seconds when it clicks leave it see blink three times then switch it's power switch off for five minutes and start the aircon by switching on it's power and put on the aircon using the remote.
How do I get the fault codes up on a Panasonic split air conditioning system CUE24FKR
14.2.2 To Make a Diagnosis1 Timer LED starts to blink and the unit automatically stops the operation.
2 Press the CHECK button on the remote control continuously for 5 seconds.
3 "- -" will be displayed on the remote control display.
Note: Display only for "- -" (No signal transmission, no receiving sound and no Power LED blinking)
4 Press the TIMER ? or ? button on the remote control. The code "H00" (no abnormality) will be displayed
and signal will be transmit to the main unit.
5 Each press of the button (? or ?) will increase error code
number and transmit error code signal to the main unit.
6 When the latest abnormality code on the main unit and
code transmitted from the remote control are matched,
Power LED will light up for 30 seconds and a "beep" sound
(continuously for 4 seconds) will be heard. If no codes are
matched, Power LED will light up for 0.5 seconds and no
sound will be heard.
7 The breakdown diagnosis mode will be canceled unless
pressing the CHECK button continuously for 5 seconds or
operating the unit for 30 seconds.
8 The LED will be off if the unit is turned off or the RESET
button on the main unit is pressed.
Diagnosis
display Abnormality / Protection control Abnormality
Judgement Emergency operation Primary location to verify H00 No abnormality detected - Normal operation H11 Indoor / Outdoor abnormal communica
tion > 1 min after starting
operation Indoor fan operation
only • Internal / external cable connections
• Indoor / Outdoor PCB H14 Indoor intake air temperature sensor
abnormality Continue for 5 sec. - • Intake air temperature sensor (detec
tive or disconnected) H15 Outdoor compressor temperature sensor
abnormality Continue for 5 sec. - • Compressor temperature sensor
(detective or disconnected) H16 Outdoor Current Transformer open cir
cuit - - • Outdoor PCB
• IPM (Power transistor) module H19 Indoor fan motor mechanism locked 7 times occurance
continuously - • Indoor PCB
• Fan motor H23 Indoor heat exchanger temperature sen
sor abnormality Continue for 5 sec. O
(Cooling only) • Heat exchanger temperature sensor
(detective or disconnected) H24 Indoor heat exchanger temperature sen
sor 2 abnormality Continue for 5 sec. - • Heat exchanger temperature sensor
(detective or disconnected) H27 Outdoor intake air temperature sensor
abnormality Continue for 5 sec. O • Outdoor temperature sensor (detec
tive or disconnected) H28 Outdoor heat exchanger temperature
sensor abnormality Continue for 5 sec. O • Outdoor heat exchanger temperature
sensor (detective or disconnected) H30 Outdoor discharge air temperature sen
sor abnormality Continue for 5 sec. - • Outdoor temperature sensor (detec
tive or disconnected) H33 Indoor / Outdoor wrong connection - - • Indoor / Outdoor supply voltage H38 Indoor / Outdoor mismatch (brand code) H50 Ventilation motor abnormality 7 times occurance
• Ventilation motor H51 Nozzle lock abnormality 2 times occurance
continuously - • Nozzle H52 Limit switch abnormality - - • Indoor PCB H97 Outdoor fan motor mechanism locked 2 times occurance
within 30 minutes - • Indoor PCB
• Fan motor H98 Indoor high pressure protection - - • Air filter dirty
• Air circulation short circuit H99 Indoor heat exchanger anti-freezing pro
tection - - • Insufficient refrigerant
• Air filter dirty F11 Cooling / Heating cycle changeover
abnormality 4 times occurance
within 30 minutes - • 4-way valve
• V-coil F90 PFC control 4 times occurance
within 10 minutes - • Voltage at PFC F91 Refrigerantion cycle abnormality 2 times occurance
within 20 minutes - • No refrigerant
(3-way valve is closed) F93 Compressor rotation failure 4 times occurance
within 20 minutes - • Compressor F95 Cool high pressure protection 4 times occurance
within 20 minutes - • Outdoor refrigerant circuit F96 IPM (power transistor) overheating pro
within 30 minutes - • Excess refrigerant
• Improper heat radiation
• IPM (Power transistor) F97 Outdoor compressor overheating protec
within 10 minutes - • Insufficient refrigerant
• Compressor F98 Total running current protection 3 times occurance
within 20 minutes - • Excess refrigerant
• Improper heat radiation F99 Outdoor Direct Current (DC) peak detec
tion 7 times occurance
continuously - • Outdoor PCB
• Compressor
Note:
"O" - Frequency measured and fan speed fixed.
The memory data of error code is erased when the power supply is cut off, or press the Auto Switch until "beep" sound heard following by pressing the "CHECK" button at remote controller.
Although operation forced to stop when abnormality detected, emergency operation is possible for certain errors (refer to Error Codes Table) by using remote controller or Auto Switch at indoor unit. However, the remote controller signal receiving sound is changed from one "beep" to four "beep" sounds.
1helpful
Car won't start.Theft light blinks,clicking sound under hood and thumping like horn wants to go off.Seems like it's stuck in anti theft mode
anti theft light should blink every few seconds.
try disconnecting the battery for 15 minutes.
Anti-Theft-Perimeter The perimeter anti-theft system consists of the following components:
  • anti-theft indicator (THEFT)
  • remote anti-theft personality (RAP) module
  • hood switch
  • keyless entry remote transmitter
  • deck lid ajar switch
NOTE: The remote entry features will not function when the ignition switch is in the RUN or ACC position.
Up to four keyless entry remote transmitters (15K601) can be programmed at one time.
The keyless entry remote transmitters :
  • Are programmable.
  • Must be set at the same time.
  • House four buttons.
  • House three buttons (Mexico Anti-Theft System only).
Programming
Refer to Section 501-14B.
Inputs and Outputs
The remote anti-theft personality (RAP) module receives input from the following components for anti-theft operation:
  • Hood switch.
  • Deck lid ajar switch.
  • Keyless entry remote transmitter.
  • Power door lock switches (LH and RH).
  • Door courtesy input.
The RAP module distributes output to the following for the anti-theft system:
  • Power door unlock relay.
  • Power door lock relay.
  • Liftgate unlock relay (Wagon)
  • Park lamps relay.
  • HORN relay.
  • Dome lamp.
  • THEFT indicator.
  • Deck lid release.
Arming
The anti-theft system can be armed if:
  • The ignition switch is in the OFF position.
  • The panic alarm is off.
  • All doors are closed.
NOTE: If a door is open, the anti-theft system is prearmed and waiting for all the doors to be closed. The THEFT indicator will remain illuminated for up to 30 minutes waiting for all the doors to be closed. If a door remains open after 30 minutes, the THEFT indicator will turn off and the system will return to a disarmed state. After all doors are closed and the 30 second prearm (continuous THEFT indicator illumination) is complete, the system is armed.
NOTE: If the theft LED does not flash after 30 seconds, check the LED FLASH PID to see if the feature is enabled.
The anti-theft system will be armed when the lock button on the keyless entry remote transmitter is pressed, all doors are closed and 30 seconds have elapsed.
When the system is armed, the THEFT indicator will flash quickly until the system is triggered or disarmed.
Disarming
NOTE: Using a key in a door lock cylinder to unlock is not a valid method of disarming the anti-theft system.
Untriggered System
NOTE: If the driver arms the system and remains in the vehicle, an untriggered system can be disarmed by turning the ignition switch to the ON position.
An untriggered alarm system can be disarmed by pressing the unlock button on the keyless entry remote transmitter.
Triggered System
NOTE: If the hood or trunk are open when the system is armed, it must be closed and opened again before it can trigger an alarm.
An armed anti-theft system can be triggered by the following conditions:
The deck lid door, liftgate, hood or any door is opened using a key, inside door handle, hood release, etc.
  • The keyless entry remote transmitter can activate a panic alarm which is similar to the anti-theft alarm, but does not cause the THEFT indicator to flash.
A triggered alarm system can be disarmed by:
  • Pressing the unlock or panic button on the keyless entry remote transmitter.
  • Turning the ignition switch to the ON position.
Alarm State When Battery Power Is Cycled
When the RAP module is supplied power the first time at the vehicle assembly plant, the system will be in the disarmed state. The RAP module will remember whether it is armed, disarmed or triggered in its non-volatile memory. When the battery positive cable is removed and then reconnected, the system will return to the state it was in just before the battery was disconnected. If the system is in any prearm state, then the system will return to a disarmed state when the battery is disconnected and then reconnected.
4helpful
How do you tune Sky+ remote into Sony KDL46W5710 Television
The Sky+ remote should automatically default to Sony TV's. Leave the batteries out for a few minutes and try again. The Code for Sony is 0000.
Or try this :-
With TV and sky box on.
Press the 'TV' button on the remote.
Hold down the 'select' and the 'red' button (of the four coloured buttons) together, until the red light on the remote blinks twice. (takes 2 seconds)
Press the 'TV' button again.
Now enter four zeros, the red light on the remote should blink twice.
Press the 'standby' button (top right).
If the TV turns off, then press 'select' and the light should blink twice again, job done.
If the TV does not turn off then press 'TV' followed by 'standby' again.
Alternate pressing 'TV' 'Standby' until the TV turns off.
When it does, finish by pressing 'Select.
Check the red light on the remote, if it blinks 3 times, then it has run out of options for 0000.
Samsung aircon cuts off. lights green/yellow flashing
lg air cond.multi split led lamp blink power 1 times,good sleep 2 times
2answers
Samsung aircon turns in 5 sec. lights green/yellow flashing
check capacitor on outside unit,or gas is leaking.
try to reset(small black button in inside unit under the cover)
TV REMOTE CONTROL NOT WORKING
1. Turn your TV on.
2. Press tv on your Sky remote control.
3. Hold down select and the red button together for about two seconds, until the red light on the Sky remote control blinks twice.
4. Press tv on your Sky remote control again.
5. Key in the four digit code for your brand of TV. The light on the Sky remote control blinks twice. If the light blinks once only, recheck the code for your brand of TV and start again at Step 1.
6. Press the standby button on your Sky remote control. If your TV switches off, press select. The light on the Sky remote control blinks twice (code stored). If your TV does not switch off, press tv, then press the standby button. Repeat this (press tv, then standby) until your TV turns off, then press select (stores code).
If at this point the LED on the Sky remote control blinks three times then all possible codes for that make of receiver have been checked. Repeat from step one, ensuring that you enter the correct manufacturer code.
At the end of the sequence, if you see the TV Guide screen, the remote control setup process is complete. If you did not see the TV Guide screen, you must now complete the following steps.
8. Press tv on your Sky remote control.
9. Hold down select and the green button together for about two seconds, until the red light on the Sky remote control blinks twice.
10. Key in the number of the channel on your TV that you use for watching satellite TV.
11. Press select on your Sky remote control. The red light blinks twice. The remote control setup process is complete.
Top Heating & Cooling Experts
Paul Carew
john h
