hi you can use master reset code to reset your mobile .you can get the codes from unlock-free here they ask you the imei number of your mobile .finally they send you the codes to reset your mobile.
have you tried to restart your phone? if not, kindly try it and if your phone is still the same way you can try restoring it to its factory setting by clicking the menu-->settings-->phone-->phone management-->factory settings and select yes but before that i suggest that you should back up your file first.
try to reset your phone settings to factory default if ask code enter 12345 its default code of nokia handsets,for reset go to settings then select restore factory settings
Hi all, I had this problem myself today- the unit receives and makes calls, receives texts but can't send them other than to the outbox.
Please try this first before taking it to the repair centre- I did a soft reset which means to restore factor settings of the unit with the sim card in (it doesn't work otherwise)
1. ** IMPORTANT**Save all your contacts and photos, etc your storage card first!! 2. Make sure the phone is on the general profile (as opposed to offline, silent or other) then type in *#7370# on the keypad. It will tell you that the phone will reset/restore settings. Click the 'ok' option when this prompt is on screen. 3. After that, you'll need to reset time, date etc. Then just copy all your contacts etc back over to the main phone and done!
