20 Most Recent
Nokia 6220 classic Smartphone Questions & Answers
Nokia 6220c change language
as u can change the layout of the menu in this phone ill tell you buy the pictures
settings is the folder with a spanner
phone settings is just a spanner
general is at the top of the list
personalize is at the top of the list (blue and yellow faces)
in that list you have
display
standby mode
tones
themes
language
voice commands
select language (5th in the list)
phone language is the first in the list
hope this helped
Nokia 6220 classic contacts will not back up to memory card
U have serious issue with your Nokia since it is doing the same thing with other memory cards - hopefully you are using a memory card that does not exceed phone specs - incorrect size of memory card can often create hassles. Check that out. Manual should reference this subject.
Nokia 302 change language
Find "Device language"
- Press the Navigation key.
- Scroll to Settings and press the Navigation key.
- Scroll to Device and press the Navigation key.
- Scroll to Language settings and press the Navigation key.
- Scroll to Device language and press the Navigation key.
2. Select language
- Highlight the required language and press the Navigation key.
3. Exit
- Press Disconnect to return to standby mode
Unlock 6220c1
Hai, A simple way to unlock your Nokia 6220c mobile you can use unlock codes. If you want unlock code you can get it from
Mobileunlocksolutions.com . They will send the code along with instructions to your mail. After you can use any gsm sim cards.
I forgot my lock code for nokia 6220 imei
Please try to enter *#7328748263373738# from standby screen and your lock code will change to default 12345. Or contact the service center to looking your lock code from flash tool
Not charging
Dear:First Option:mostly nokia chargers doesn't make problems...just try the following..connect ur mobile with a system (usb cable)...found out whether it is charging or not...if the same prblm appears then there is a prblm in ur cell phone or power jack(socket)...if it charged with usb cable buy a new chargerPlease change Phone Bettery and check the chargingIF Charging Problem not Solved SoSecond Option:Your Phone charging IC Fault So Please change charging ICAnd charging Problem will Solved Quickly
Securty code unlocking
ur defalt phones codes is 12345 or 00000 u can use it Default 4 Digit user code: 1234 or 0000Default 6 Digit Security code: 123456 or 000000Type *#06# at the mobile screen to know IMEI no of your mobile.send the IMEI no to me and i will reply you with unlocking code.IF Problem not Solved SoPlease New Software install in the Phone Problem will SolvedIf For puk & pin cod problem So PleaseVery Best Solution:You Go To Service & Sim Office and Get The Puk code And Pin code From Office opratorEnter The Puk code and YesEnter The pin code and YesSo Puk code Open and Problem will Quickly Solved
Ringer jumper
mY dear Your Phone Ringer Default So Please change RingerAnd Ringing Sound Problem will solved
Reset call barring
Did you try your sim card in another handset and did you experience the same issue? Could you try 1234 as the password.Cheers.
I need to unlock it
hi you can use codes to unlock the mobile .it will be helpful for me if you had specified the country from where you brought the mobile to guide you the exact place to get the solution for your problem .however you can get the codes from here
wickedunlockhere they ask the imei number of the mobile .then finally they will render you the unlock codes as fast as possible.
I cannot send txt to
try reinstalling your phones firmware using nokia software updater. it will solve your problem.
goodluck
