20 Most Recent Nokia 6700 Classic Cell Phone Questions & Answers
7answers
Restriction code for nokia 6700c-1
For the best place to get the restriction code for your Nokia 6700C model mobile,
Just visit this site www.mobile-unlocker.com , it has the best instructions and simple methods for getting the restriction code for your Nokia mobile from the network lock........Once you get the code after that you can use it with any other network's sim card.
7/12/2019 11:06:54 AM • Nokia 6700... • Answered on Jul 12, 2019
2answers
Remove cable or connect a
hi
go to your settings menu in your phone and select connectivity option.there you should choose ask on connection option.then restart your phone.and after restarting also ensure the connectivity settings.if you still have same problem you can contact your serviceman
4/30/2019 5:51:44 PM • Nokia 6700... • Answered on Apr 30, 2019
2answers
Nokia 6700c security code
Hi,thanks for using fixya,
Just follow the steps
Take a full backup.
First Try it:
You may try default phone and security code to remove it
Defalt phones codes is 12345 or 00000 you can use it
Type *#06# at the mobile screen to know IMEI no of your mobile.
send the IMEI no to me and i will reply you with unlocking code.
If
Soft reset( factory setting)
On Sybmian phones:
*#7780# - Restore factory settings
*#7370# - Reformat your phone (back up your personal data with PC Suite or to the memory card first!)
Hard reset
Back up your personal data with PC Suite or to the memory card first!
Switch-off your phone.
1. Press and hold three keys at a time;it is called "3 finger reset" which is depress these three keys simultaneously "*" "3" "green phone" and then power on phone whilst keeping those same three keys depressed until you see formatting.
If you dont understand, again follow the step.
You will use three finger for pres three keys ."green phone"+ "3" +star( *) and pres the power on switch.
All switch will be pressed at a time.
Soon an formatting text, will appear ,then stop pressing those switch,
Remember.
2. After a few minutes when the Full phone formatting completed, your phone will back to original system and factory stetting.
Hope this helps.
There is an rate option "Was this helpful?" Yes or No.
If you are helped you can rate and leave a short comment,that is your choice.
Hope this helps.
If you are helped you can rate on the 4 thumbs and post a short comment,because,
this is the free side and I can get the chance, to help people like you .
Thanks for using fixya .
12/2/2018 7:44:05 PM • Nokia 6700... • Answered on Dec 02, 2018
Trycktill unlock unlock swe code nokiafree
I wont to help password for nokia 105
10/23/2017 9:05:09 PM • Nokia 6700... • Answered on Oct 23, 2017
Nokia 6700 blank screen but turns on
screen damage replace it or clean the conector port of display
10/7/2017 7:46:27 PM • Nokia 6700... • Answered on Oct 07, 2017
3answers
I'm trying to rest my mobile Nokia 6700 to reste factory asking for security code
Hello it is not a hard task just follow this How to Generate Your Phone Security code..Only for Nokia bb5 to generate the security code.First thing you need to collect is nokia USB compitable cable.After you got the code,easily restore your phone with the generated code.Good luck.Thanks for visiting fixya
2/22/2017 9:35:34 AM • Nokia 6700... • Answered on Feb 22, 2017
How to turn off the
Go to Menu > settings > profiles > general and set Warning tones to off.
3/7/2016 4:04:44 PM • Nokia 6700... • Answered on Mar 07, 2016
2answers
I need country code for
Steps
  1. Download software to generate the unlocking code. Software is available on some websites for free and some pay websites that also offer support if things go wrong. Find the Serial number of the cell phone, also known as your IMEI number. This can be done by either removing the back of your cell phone and looking underneath the battery, or simply by typing in *#06# into your cell phone. It should looking something like: 010082321439976
  2. Using the software you have downloaded, enter in your Manufacturer (which is in this case Nokia), your model number, and your IMEI number. Also enter your country and the Network. Calculate the code, this may be different depending on which software you are using. If your phone is the Nokia 3390 phone, select the model 3310, they are the same phone.
    You will get a series of codes that looks something like: #pw+555 979 507 5+1#. You will enter each of these codes until you find the one that works for you, it’s possible the first one won’t work.
  3. Remove the SIM card from your Nokia phone. This is typically done by removing the back cover of the phone and removing the battery and sliding the card out. Put the battery back in and power the phone on.
  4. You should see a message “Insert SIM Card”. Begin entering your generated code. Enter all of the characters you see in your code, including the # symbols. To get a ’p’ press * 3 times, to get a ’+’ press the * key 2 times, to get a ’w’ press the * key 4 times. Disregard any spaces in the code.
  5. Once you have finished entering a code that works you should see a message that says “SIM is not restricted” or “Restriction off” message depending on your model. If not, try entering another code. Be careful, entering a wrong code 5 times will mean that you will only be able to unlock the phone with a data cable.
Warnings
Attempting to unlock your phone is done at your own risk. Although unlocking your phone is legal, some cell phone operators might choose to void your warranty should you unlock your phone (then again, some cell phone operators won’t mind).
link: http://wiki.ehow.com/Unlock-Your-Nokia-Cell-Phone
8/1/2015 8:07:30 PM • Nokia 6700... • Answered on Aug 01, 2015
Phone sim is close . I forgat PUK cod
you will have to go to the service provider and get a new sim.
3/11/2015 5:16:19 AM • Nokia 6700... • Answered on Mar 11, 2015
2answers
Restriction code for nokia 6700c ime 352696048675861
If you mobile displays Restriction Code, then it is locked with some network and requires a code to be entered, to allow your mobile to use any network. Restriction code for your Nokia 6700C model mobile can be got at Unlocking4u.com which gives easy instructions to unlock your mobile.
12/27/2014 10:35:27 AM • Nokia 6700... • Answered on Dec 27, 2014
2answers
If you mobile displays Restriction Code, then it is locked with some network and requires a code to be entered, to allow your mobile to use any network. Restriction code for your Nokia 6700C model mobile can be got at http://www.unlocking4u.com/nokia-6700-classic/rs6wp9/ which gives easy instructions to unlock your mobile.
12/27/2014 10:33:19 AM • Nokia 6700... • Answered on Dec 27, 2014
2answers
My bluethooth is not working.
Why don't you flash your phone with a new rom...i think that will help
10/6/2014 11:33:18 AM • Nokia 6700... • Answered on Oct 06, 2014
Free o2 restriction codes for a nokia 6700c-1
To unlock your phone You need not have that particular Sim. you can unlock it using your very own sim.You can get the Restriction code for your Nokia 6700 Classic phone from Mobile-Unlocker.com here you need to specify your country,Network name to which it is locked,IMEI number of your phone.
8/4/2014 11:54:02 AM • Nokia 6700... • Answered on Aug 04, 2014
2answers
I enterd a wrong pin
PUK codeand PIN Code: Pleasedon't try more than 3 times.If you try more than 3 times the Sim will getlocked.And it will ask for PIN code.Both these PUK and PIN code can be givenonly by the network service provider. Please call the network service providerof your mobile.And ask him to provide the PUK code or PIN code.He will ask yousome basic details like name,date of birth for his verification.And hewill provide you the PUK and PINcode.This is done for free of cost.
Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thank you for using fixya have a nice day:-)
7/3/2014 8:17:14 AM • Nokia 6700... • Answered on Jul 03, 2014
0answers
0answers
2answers
ALLAWAY BATTRY LOW AND
It may not be as simple as you think.
Usually this happens when a phone suffers water damage. If buying a new battery didn't help, then I assume that the phone either suffered water damage or is having a software problem
I would bring the phone to the nearest store location of your phone carrier and ask them to check if it is due to water damage. If it isn't they should replace the phone free of charge. If it IS due to water damage, you're probably going to have to pay a little to get a new one. I'm sorry about your problem. Hope this helped, though. Please rate my solution!
- Frankie
4/7/2014 3:40:38 PM • Nokia 6700... • Answered on Apr 07, 2014
Nokia 6700 Classic Cell Phone Logo
707 questions posted
Top Nokia Cell Phones Experts
Kolbrun...
Marvin
Marvin
matt
matt
View Most Popular
Classic Nokia
  • Classic Nokia
Most Popular Question
bluethooth not working
  • Cell Phones
