Samsung LA40A450 40 in. LCD TV Logo
Anonymous Posted on Jan 18, 2011
I notice my lcd brightness has reduce now this is 2 years old this problem remains same on Dynamic picture mode as well i have check this by connect to a pc and to a DVD using HDMI port and i tested non energy saving mode as well if i change energy saving mode and the picture mode (dynamic , stranded or move mode ) brighteners level change but not as l early days
Electro Med Services
Level 3:
  • Samsung Master 6,694 Answers
  • Posted on Jan 18, 2011
Samsung Master
Level 3:
Answers
6694
Questions
Helped
1872715
Points
21433
First of all check the back light setting of your tv. you can see it on the picture setting menu.
Just check when you adjust the back light setting, is there is any change. if it changes and still not attaining the needed brightness level, then you have to check the back light inverter and the CCfL( cold cathode fluorescent lamp) used as back light. if there is no change in the black light, then the logic board or the inverter have some problem.
you have to check the inverter first is it getting the correct voltage from the power supply normally 24v.
if the voltage is ok , then u can do only one thing replace the inverter board to check whether the lamb have any problem. in normal case the inverter will become faulty. lamp fault is rare.
check all these. If you need further assistance fell free to contact me through fixya.
ok
  • Electro Med Services
    Electro Med Services Jan 18, 2011
    hi,
    also check the electrolytic capacitor in the power supply and inverter board.
    ok
My astron 32" tv is too bright i set it too the lowest Backlight setting but still too bright for me please help
1 .Picture Mode: Explore different picture modes on your TV. Some modes might have preset configurations that affect brightness. Choose a mode that suits your preferences
2.Advanced Settings: Look for advanced settings or options related to color temperature, gamma, or dynamic contrast. Tinkering with these settings might provide more control over the display.
My 32 EF 323 provoview tv is so bright. I cannot
The brightness control does the dark parts of the picture. Contrast does the bright parts.
Take the TV off Dynamic mode and put it in to user mode.
1helpful
I can't get the color right. What are the perfect setting?
Hello!
Have you tried preset picture modes off TV's "picture" menu or "picture" on remote control unit. Most modern sets have "preset" modes: normal, vivid, natural, movie, sports, user, etc. Try to toggle between those modes. may be the one of those will look right for you. Make sure: "user" mode is for custo adjustments. You must choose desired settings: "picture(contrast)", "brightness", "color", "tint", "sharpness", "color temperature". May also have: DNR(dynamic noise reduction", "black level expansion", etc. I'd try presets, first and make notice of those settings. If that is, still not right to you, you may be able to tweak "user" mode the way you like it, based on info from other modes. If that won't help, you may have an issue with your TV.
good luck,
thanks,
Alex.
1helpful
LOOKING FOR PICTURE SETTING SAMSUNG MO.NO.LN-T5265F
This may help you...you can also get an owners manual free on line.
English - 23
Using Automatic Picture Settings
Your TV has Three automatic picture settings ("Dynamic", "Standard", "Movie") that are preset at the factory.
You can activate either Dynamic, Standard, Movie by making a selection from the menu.
1. Press the MENU button to display the menu.
Press the ENTER button, to select "Picture".
2. Press the ENTER button to select "Mode".
Press the ??² or ??¼ buttons to select the "Dynamic", "Standard", "Movie" picture
setting. Press the ENTER button.
?³ Choose Dynamic to increase the clarity and sharpness of the picture.
?³ Choose Standard for the standard factory settings.
?³ Choose Movie for a natural Image without picture enhancements.
3. Press the ??² or ??¼ buttons to select "Contrast", "Brightness", "Sharpness",
"Color", or "Tint(G/R)", then press the ENTER button.
4. Press the ??? or ??? buttons to decrease or increase the value of a particular item.
For example, if you select "Contrast", pressing the ??? button increases it.
Press the EXIT button to exit.
• When you make changes to Contrast, Brightness, Sharpness, Color, Tint(G/R)
the OSD will be adjusted accordingly.
• When in PC mode, Tint, Sharpness, and Color are not available.
Press the P.MODE button on the remote control repeatedly to select the desired
picture mode.
Picture Control
Move Enter Return
Mode : Dynamic ???
Contrast 1 00
Brightness 50
Sharpness 85
Color 55
Tint G 50 R 50
Balck light 1 00
??¼More
TV Picture
Move Enter Return
Mode : Dynamic
Contrast 1 00
Brightness 50
Sharpness 85
Color 55
Tint G 50 R 50
Balck light 1 0
??¼More
TV Picture
Dynamic
Standard
Movie
Move Enter Return
Mode : Dynamic ???
Contrast 1 00
Brightness 50
Sharpness 85
Color 55
Tint G 50 R 50
Balck light 1 0
??¼More
TV Picture
50
??² Con trast ??¼
Move Adjust Return
English - 24
Adjusting the Color Tone
You can change the color of the entire screen according to your preference.
Press the ENTER button to select "Picture".
2. Press the ??² or ??¼ button to select "Color Tone", then press the ENT ER button.
3. Press the ??² or ??¼ button to select "Cool2", "Cool1", "Normal", "Warm1",
or "Warm2".
When the picture mode is set to Dynamic or Standard, Warm1 and Warm2
cannot be selected. Movie mode is only available.
Move Enter Return
??²More
Color Tone : Cool2 ???
Detailed settings ???
Size : 16 : 9 ???
Digital NR : Low ???
Active Color : On ???
DNle : On ???
Reset : OK ???
TV Picture
Move Enter Return
??²More
Color Tone : Cool2
Detailed settings
Size : 16 : 9
Digital NR : Low
Active Color : On
DNle : On
Reset : OK
TV Picture
Cool2
Cool1
Normal
Warm1
Warm2
Activating Backlight
You can adjust the screen brightness by adjusting the LCD backlight brightness. (0~10)
2. Press the ??² or ??¼ button to select "Backlight", then press the ENTER button.
3. Press the ??? or ??? button to decrease or increase the valueof the backlight
brightness.
Move Enter Return
Mode : Dynamic ???
Contrast 1 00
Brightness 50
Sharpness 85
Color 55
Tint G 50 R 50
Balcklight 1 0
??¼More
TV Picture
5
??² Balcklight
??¼
Move Adjust Return
Move Enter Return
??²More
Color Tone : Cool2
Detailed settings
Size : 16 : 9
Digital NR : Low
Active Color : On
DNle : Off
Reset : OK
TV Picture
OK
Cancel
Resetting the Picture Settings to the Factory Defaults
1. Press the ??² or ??¼ button to select "Reset", then press the ENTER button.
Press the ??² or ??¼ button to select "Cancel" or "OK" then press the ENTER button.
Each mode can be reset.
4helpful
T.V. won't allow me to adjust color and sound...
Chepe_77,
You are absolutely correct. The reason why you cannot change your audio and video settings are due to the fact that you are in "Dynamic Fixed". Which is one of your many av modes. Av modes are different preset color settings and dynamic fixed is the only one that will lock your settings. Best Buy set it that way so that people could not just come by and alter the settings on the unit. AV modes are on all sharp lcd products and even though you have the wrong remote you should have an av mode button on the remote that came with it. Try pressing the av mode button and see what happens. When you press the av mode button, you will see your av modes change at the bottom of the screen. However, the issue still remains that you have the wrong remote. So there is a chance that you may press the av mode button on the remote that you have, but it still will may not work ONLY because you have the wrong remote. If the remote you have does not work, I GUARANTEE that pressing the av mode button on the proper remote will take care of that. If you dont want to purchase the remote from sharp, www.partstore.com is a good place. Good luck to you
2answers
What are the best picture settings for the 52" Sharp Aquos LCD
I'm happy with:
backlight +16
contrast +40
brightness +1
colour -13
tint 0
shaprness +2
although I found this setup but haven't tried it yet
backlight +5
contrast +24
brightness -7
colour +50 (review I found didn't say + or -. Try both
tint 0
sharpness -5
Len
1helpful
2answers
Picture setting regularly changes to dynamic from standard
You need to change the option throgh the service mode.
You can not access that mode without permission from Samsung.
better to contact Samsung call center.
1helpful
Bad picture/colours on Samsung LCD TV
loretta change your power pack
entwined  try another cable
3answers
Samsung tv settings
it depends on what your using it for, adjust colour tones to what you think looks natural, contrast between 80-90, keep sharpness below 30. just have a play around till you find what best suits the source material.
2answers
Samsung LE46F8 picture setting
It sounds like your TV is in Shop Mode.
Shop mode is a set of picture parameters that have been optimized for a store showroom or display floor. Shop mode does not allow you save any picture settings such as brightness or contrast.
To get the TV out of Shop Mode press and hold the Menu button on the front panel for three seconds, the picture will blank momentarily then reappear with “Dynamic Mode” shown on the screen. At this point the picture parameters can be changed and saved.
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
