Question about Samsung LA40A450 40 in. LCD TV
My samsung tv sound keeps cutting out. I have to
My samsung tv sound keeps cutting out. I have to turn the tv off and on again to get the volumn back.
Posted by java521 on
dick davis
  • Samsung Master
  • 610 Answers
Either you have a loose connector going to speakers or the main board is failing.call 1-800-samsung for nearest service center.
Posted on Dec 02, 2009
I've got a rcs STAV 3880 surround receiver wit ful volumn al the time
Sounds like a shorted audio IC or bad connection in the limiter circuit.
Mar 01, 2014 | RCA Optimus/Stav-3880 Rcvr Parts - Board -...
Samsung lcd volumn ok with dvd very low with tv only
What is it connected to when the volume is low? How is it connected
Feb 06, 2013 | Samsung LN-S3251D 32 in. LCD HDTV
My volumn doesn't work when using the HDMI cable
Your TV and the cable box may not be compatible via HDMI or the digital audio format of the cable box is not set to PCM (contact your cable provider for information on how to change this on your cable box... too many models to speculate). The easiest solution is to use the component connections on the box and the TV (5 wire - Green, Blue, Red, White, Red). This will give you HD and eliminate to question of compatibility. I hope this was helpful, best wishes.
Apr 22, 2010 | Sharp Aquos LC-46D62U 46 in. LCD HDTV
Samsung lcd-tv is making a buzzing noise
I have been having that same buzzing sound. It happens when you turn on the energy saver feature on the tv setup. Just turn it off. Smooth
Jul 15, 2008 | Televison & Video
My tv
My tv will not turn on. We had been away for a week and no power interuption at home. We have unpluged the tv for short and long periods of time . We we attempt to turn the power on it cuts off by itself.
Mar 01, 2008 | Televison & Video
Volumn not working
WHen I hit the mute button again to bring up the volumn the sound remains muted. I have tried all other channels, direct cable and even a dvd player connected. No sound. I unplugged all the boxes and tv and then plugged in again in a attempt to reset what might be wrong. Still no sound. solution 1 while operation mute button has got demaged or pressed more. 2 sound section might have gone defective in tv 3 no supply to sound section 4 or speaker defective or ic got demaged.
Aug 02, 2007 | RCA 27V520T 27" TV
Samsung LA40A450 40 in. LCD TV Logo
3,550 people viewed this question
Muntejaya Ginting
Muntejaya Ginting
Demonic-2011
Demonic-2011
