I cannot copy pictures from my camera onto my computer. I have tried numerous times on several different laptops. I only have 51 pictures on my memory stick, and a few videos. The bar across the top of the screen is green all the way across, but keeps trying to load the pictures. I'm getting very frustrated because I've been trying to get the pictures off of my camera for months. Please help!
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo management program such as Picasa ( http://picasa.google.com ).
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program.
It might not be able to display some photos (different sizes or compression) from a different camera or jpeg files copied onto the card from a computer. If the all the pictures are from the camera then the card could be corrupted. Try recovery software such as the free : http://www.piriform.com/recuva if some files can not be read. Copy the pictures onto a computer then format the card in the camera to erase it.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use iPhoto or any other photo cataloging program.
Consider NOT connecting your camera to your computer.
Each time you execute finalization, the disc remaining space will decrease by approximately 13 MB. If you don’t have enough room, it won’t allow you to finalize the disc.
To finalize this disc, you have to delete some pictures to make enough space. But don’t worry, before you delete those pictures, you can save them to your computer.
Find out the CDs came with your camera, refer your manual page 51 - 61 to install ‘PIXELA PTP Manager’ , connect your camera and computer with USB cable, and copy some pictures to your computer, then delete the pictures on camera side. If still not enough room, copy more and delete more. make it enough to do the finalization.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo management program such as Picasa: Organize edit and share your photos
Try to change the USB connection type in the camera menu. There are several types like Mass storage, Pict. bridge, and the one you need is most likely PTP. Anyway, try all of those and maybe it will work. That is the most common problem when connecting cameras to Vista based systems.
