My ford freestar 2004 has a light that came on when I was driving with a ! circled blinking and I looked in the book, it says check transaxle. Also my check engine came on. What should I do?
Hi, This could be a sign of lack of oil in the axle, if you could just check that out first & refill the axle that may fix problem. Should that not solve problem I think if you drive it home carefully it should hold out enough to get you home. Please leave me feed back: Malcolm Campbell, Thanks.
Could it be an exclamation (!) in a circle? If it is, that is the warning light for your brake system. Check the fluid level at the master cylinder, add if needed, and check for brake fluid leakage under the car. Be careful, as you may lose your brakes if the fluid level drops too low. If this is NOT the symbol you see, let me know, I'll try to find another explanation for it. If it is a ? inside a cutaway of a tire, (kind of a 'U' shape with a question mark in it) it is your tire pressure monitoring system warning of low tire pressure in one or more tires.
