Wireless CSR4.0 Portable Bluetooth Receiver Wireless Hands Free Calling for Home 3.5mm Audio Out Music Streaming Sound System Amazon com Charm sonic Wireless CSR4 0 Portable Bluetooth Receiver...
Emailing and sending pics will work. contact me at [email protected]. I tried to send them to you is this solution box but couldn't get past the 6th or 7th line.
I'll try to enter the LG290c procedures for emaling pictures a 2nd time. 1. enter email address you wish to send to in their contact information. 2. Select messages (3rd menu icon) 3. select new picture message 4. select options. 5. select contacts. 6. scroll to person your going to send pics to (do not press enter yet) use left/right keys to select their email address, which you will see at bottom of screen. 8. press enter (a check mark is now in the box at left of their name. 7. click done. (their email address should now be on the "to" line of your msg to them. 8. Scroll to image line and press add. 9. select image and press"set". 10. send picture. I hope this helps. I couldn't fit it all in the solutions box, the first time I tried.
To send or receive pictures or any file, you need to be sure that your phones bluetooth is turned on, without it your phone will not be able to send or receive pictures or any files. Also, you can transfer files to a computer using a USB cable, connect it to a computer and other devices that Has a USB hub. Files can also be transferred through the SD memory card, you can transfer pictures to the memory card and remove it from your device, then you turn off your phone, remove the memory card, install it into other devices that allows memory cards, then you copy pictures from the memory card to other devices.
To use your bluetooth in transferring the pictures from your phone to other bluetooth devices, then you turn on youe bluetooth by going to the phones menu, select the settings, then you go to the bluetooth and turn it on, make sure the bluetooth device of other phones and devices are turned on then you select the picture to send and select via bluetooth, it will search for the available bluetooth devices, then you select the one you are willing to send your pictures to then you either pair id the device is not familiar, ensure you use a password that is easy to remember to pair with the other device.
That way your phone will be able to send the pictures. That should solve the problem.
Hope this information assisted you!
