20 Most Recent
LG BL20 Cell Phone Questions & Answers
RECOVER DELETED PHOTOS
First thing to note is that the deleted data on the phone will remain there until something new is saved and overwrites it. This might not happen immediately but eventually, after continued use, it will.Either connect the phone straight to a PC using a USB cable (if supplied with the phone) or take the card out and put it in a card reader attached to the PC. You should see memory card shown as a drive letter (like H:) in Windows Explorer.Then try some
pic recovery software on the PC. This should recognise the phone or card and then you can scan it using the free download of some good photo recovery software. That will show you what files still exist on the phone or card and what can be recovered.
http://www.asoftech.com/articles/mobile-phone-data-recovery.html
Display
you need a new screen as the lighting element has burnt out you can grab these at any market stall be prepared to haggle with the price and all you will need is either t5 or t6 torque screwdriver to undo all the screws if still under warranty take it back to the shop and they will repair for free
SIM Inisiliging showing tuch centre
If you meant SIM not detected and contact service: then please do accordingly after checking the SIM contacts to clean and set it in.
If not contact LG service.
When I turn off my
when you do change the language you have to save this operation .then it will be saved even if you turn it off and re turn it on
PUK mymobil do not know.Where
To get PUK code please contact your service provider.they will provide you the defaultPUK so that you can open your phone.
While you get the PUK code ,the serviceprovider customer care officer will askfor your personal details to checkwhether the mobile belongs to you only.If they are satisfied with your answers they will providewith the PUK code
Note: if you keep entering random/unknown numbers/codes, the sim card will be lockedand will be rejected. It'll not beusable anymore.
If you need further help, let me know.
Good Luck.
Thanks for using FixYa.
PUK's mymobil do not know.Where
Hi, your PUK code can be given only by your service provider which is specific for each and every mobile number. Contact your sim customer care department over phone. It's free of cost to get the pin or puk no. If you can't contact through your phone get some other phone and contact them, or go to the nearest service outlet of your service provider they can also help you.
PUK code is also on your SIM card documentation Starter Pack. If you do not have this then -Please contact your phone service provider................
Can an LG Stylo 4 with a cracked screen , showing only a black screen be repaired so i may extract data from it ?
It is possible to repair an LG Stylo 4 with a cracked screen that shows only a black screen to extract data from it. However, the success of the repair will depend on the extent of the damage to the screen and other internal components.
You can take your device to a professional phone repair shop and ask them to repair the screen. Once the screen is repaired, you should be able to access your data on the device. If the screen repair is not possible or too expensive, you may be able to extract data from the device by connecting it to a computer with a USB cable and using a data recovery software.
Note that data recovery software may not be able to recover all the data from the device, especially if the device has suffered significant damage. It's always a good idea to regularly back up your data to avoid losing important files in case of accidents or device failure.
