Cyberhome DVR 1600 DVD Recorder Logo
Posted on Dec 25, 2010
Is there any way to convert the mtk file to mpeg, wav, or anything else?
1helpful
3answers
I have g4 mac 9.2. i need saported softwer for braus & plye vediyu
Leawo Video Converter is an all-in-one best video converter for downloading to convert videos among popular formats like AVI, MPEG, WMV, MP4, FLV, RM, MOV, Xvid, 3GP, etc., transform audios between MP3, WMA, WAV, M4A, AAC and AC3 audios, and create fascinating photos from video files.
tip
Video Converter for Mac to Convert MTS, MP4, MOV, H.264, etc on Mac(including...
Doremisoft Video Converter for Mac is the perfect software for Mac users to convert all sorts of videos on Mac. It supports converting SD video such as MP4, WMV, AVI, MOV, MPEG-1, MPEG-2, etc;HD video including MKV, MOD, AVCHD MTS, M2TS, TOD, HD MPEG-4 etc.
With Doremisoft Video Converter for Mac, you can easily import all kinds of videos to iMovie, iTunes, Quicktime, FCP, FCE,iPad, iPod, iPhone, Blackberry, PSP, PS3, etc. This Mac Video Converter is also a best Audio Converter that can convert between audios such as MP3, WAV, AAC, M4A, AC3, FLAC, MP2, MKA, AMR, etc and allows you extract audio from video.
Doremisoft Mac Video Converter is also a powerful editing tool that can trim video; crop video; capture image from video to JPG, PNG, GIF or BMP, etc; set effects like Brightness, Contrast and Saturation; merge several video into one and so forth.
All in all, Doremisoft Video Converter Mac is easy to use and the best choice to convert video on Mac and edit video for Mac.
Key features of Video Converter for Mac
Support Converting all sorts of SD/HD Video and Audio
Video: AMV, MOV, WMV, 3GP, 3G2, VOB, MPG, SWF, FLV, AVI, DV, M4V, MP4, MKV, H.264/MPEG-4 AVC, DivX, XviD, RM, ASF, MPEG-1, MPEG-2, MPEG-4, MXF file, AVCHD, M2TS, MTS,TRP, TS, MOD, TOD
Audio: MP3, WAV, AAC, AC3, MP2, FLAC, OGG, AIFF, MKA, RA, APE
Easily Convert Audio/Video for Various Players and Editors
Player: iPod, iPhone, iPad, PSP, PS3, Apple TV, BlackBerry, Archos, Creative Zen, iRiver, etc.
Editor: iMovie, iDVD, Final Cut Pro, FCE, iTunes, QuickTime, etc.
Extract Audio from Video Files
Extract audio from video files and convert among popular audio formats including MP3, M4A, AC3, WAV, OGG, AAC, APE, MKA, etc.
Capture Pictures
You can take a screenshot of your favorite scene from videos and save it in JPG, or PNG formats
Powerful Editing Function
Trim: trim/clip any video segments.
Crop: crop frame size to remove any black or unwanted parts and set aspect ratio, 16:9, 4:3, full screen, etc.
Effect: set brightness, contrast, and saturation; select special effect: gray, emboss, old film, etc.
Output Parameter Settings: Resolution, Frame Rate, Encoder and Bitrate of video, Sample Rate, Channel, Encoder and Bitrate of Audio
Preview: preview window for you to preview the original file and the edited and compare them side-by-side.
Merge: Merge several videos into a whole one.
Batch Conversion
Batch conversion mode enables you to convert more than one files with fast conversion speed.
on Oct 22, 2010 • Computers & Internet
tip
I like using Nidesoft Video Converter.Itcould convert video and audio files...
Read this guide and learn how to rip a DVD to all modern video formats and convert video between any video formats, including AVI, DivX, XviD (*.avi, *.divx, *.div), MPEG-4, H.264 (*.mp4, *.m4v), MPEG-1, MPEG-2 (*.mpeg, *.mpg), DVD (*.ifo, *.vob), Quick Time (*.mov, *.qt), WMV, WMV-HD (*.wmv, *.asf), 3GPP, H.263 (*.3gp, *.3g2, *.3gpp, *.3gp2), Real Video (*.rm, *.rmvb), SWF (*.swf) using AVS Video Converter from AVS Video Tools.
This program has a very simple and intuitive interface. The "learning curve" is near zero. You will start working from the first launch. All you do is enter in the video or DVD to be converted, where you want it to be stored and the location of your CD/DVD Burner or Portable Media Device and the software does the rest. Just follow step by step instructions below:
Step1. Download AVS Video Converter
For more features about it, you can refer here.
Step2. Launch AVS Video Converter
Start > All Programs > AVS Media > AVS Video Tools > AVS Video Converter
Step3. Select Output File Type
Click the To AVI or To DVD or To MP4 or To 3GP or To MOV or To WMV or To RM or To SWF button along the top of the interface.
Step4. Choose Video File or DVD
Click the uppermost Browse button on the right. Navigate to the location where you keep your video files or DVDs, and select the video that you would like to convert. Click Open.
Note: When your input is a DVD Disc, you will need to select the path to your source file: X://Video_TS/Video_TS.IFO. "X" stands for your DVD-ROM or the hard disk drive folder where your DVD is stored.
It is important to select the IFO file, rather than VOB or VRO file, because the IFO file contains the information about the entire DVD structure and this way you will avoid audio and video de-synch problems when converting. Also, most DVDs have several VOB or VRO files (files with actual video) and if you convert VOBs or VROs instead of IFO, you will have to merge them afterwards, which is not the case with the IFO files.Anyway if you have only VRO or VOB files, select them. AVS Video Converter converts these files perfectly too.
Step5. Select the Output Location
Click the bottom Browse button on the right. Choose the location where you would like to save your converted video file. Click Save.
Step6. Select the Output Format Profile
In the list of Profiles select one of the available profiles or click Edit Profile button to manually set the output video profile parameters.
Step7. Convert Video
Click Convert Now and step away from the computer (processor performance will be seriously affected during conversion). If you want to watch the progress while you convert, click the Advanced button until the viewing screen pops out of the bottom.
avs-video-tools-6.png Besides this you can also refer to other tools such as blu ray ripper to get more information
Or you can visit dvd burning software to find some useful information about how to burn dvd to your pc.
I do hope these resources can help you. good luck to you!
on Jul 23, 2010 • Computers & Internet
4answers
Is it possible to import MP4 files into Windows Movie Maker 6.0 without having to convert to a different format first? I have a Pinnacle Video Transfer device that creates MP4 files, that I want to...
Windows Media Player 11 recognizes and plays MPEG-4 just fine but WMM doesn't recognize them. I would like to import some MPEG-4 files into Movie Maker and work with them - is there a codecs or something that allows this?
I'm sure I can find a program to convert MP4 into a format MM will recognize but if possible I'd like to just skip the conversion step and work with MP4 directly in MM.
Thanks!====================================================
Movie Maker is not compatible with MP4 files...
best bet would be to convert them to .wmv.
The following freebie might be worth a try:
Format Factory
http://www.pcfreetime.com/
All to MP4 / 3GP / MPG / AVI / WMV / FLV / SWF.
All to MP3 / WMA / AMR / OGG / AAC / WAV.
All to JPG / BMP / PNG / TIF / ICO / GIF / TGA.
You need some software to convert the protected M4P music file to unprotected MP3, WAV etc first, then you can import the mp3 files into Windows Movie Maker as background music.
TuneClone is such a software to convert the M4P music file to MP3, WAV easily. You can click here to download TuneClone and convert them to MP3 files and then import the music files into Windows Movie Maker project.
TuneClone uses a virtual CD burning technology to simulate the burning and ripping process and can convert M4P files to MP3 without any CD-R disc and do this work quickly. TuneClone installs a virtual CD-RW, it helps you burn any unprotected or DRM protected M4P, M4a, WMA music files onto the virtual CD, rips tracks on the virtual CD, encodes tracks onto MP3, WAV or WMA music files. It can repeat this audio converting procedure until your whole music collection is done.
Since the virtual CD emulates your computer RAM and hard disk as erasable CD-RW drive (Virtual CD-RW), the converting speed is faster than any other m4p to mp3 conversion programs.
Windows Movie Maker is video creating/editing software that is included in recent versions of Microsoft Windows. It contains features such as effects, transitions, titles/credits, audio track, timeline narration, and Auto Movie. New effects and transitions can be made and existing ones can be modified using XML code.
1helpful
3answers
How to import MOD into windows movie maker ?
I prefer Wondershare video converter, it could not only convert MOD files to Windows movie maker but also the best HD video converter and AVCHD video converter which can convert HD video and AVCHD video to avi, convert m2ts to avi, convert mts to avi, convert ts to mp4 etc.. with excellent quality.
tip
I always use Nidesoft Video Converter.It could convert video and audio files...
Apple's iphone 4 has been launched since June 7, 2010, which becomes a hot topic to iPhone users. The fourth iPhone features two cameras(one on the front and the other on the back), iPhone 4 makes people dreaming about video calling for decades a reality, what’ more, iPhone 4 has powerful HD Video recording and editing function.
However, iPhone 4 supprted video formats are very limited, so if you want to watch your MKV files on iPhone 4, all you need is to convert MKV Videos to iPhone 4 supported such as MP4, H.264 with a MKV to iPhone 4 Converter.
Mac MKV to iPhone 4 Converter not only convert MKV to MP4 for iPhone, but aslo can convert MKV to 3GP, convert MKV to MOV, convert MKV to DV, convert MKV to MPG, and some other popular video formats , which are compatible for iPhone, Palm, Walkman, iMovie Video, PSP, Blackberry, Gphone, etc.
on Jun 18, 2010 • Computers & Internet
How do i convert an mpeg2 file into mpeg?
Please open the link provided below and follow the steps provided on it to convert the file format to WAV.
http://support.d-imaging.sony.co.jp/www/disoft/int/pmb/feature/edit/wmv_convert.html
You may try converting the file format to WAV. However, operation is not guaranteed.
4helpful
3answers
Video format for wharfedale FM6709 4GB Black
video converter is a classic collection of all the excellent programs for video conversion of the world today. It delivery the ultimate solutions for the troubled people who desire a magic tool that can be used to convert one video to many others at will. It is just more than your can imagine, it also allows users to extract audio track, take snapshot from videos. With the customizable settings function, you can get more artistic effect form the converted video. Just email your friends the processed music, video or pictures as a gift or a symbol of greeting, share your achievement with your friends from today now. The iOrgsoft video converter is simply the right choice for all your needs.
The supported output formats and mobile devices:
1. Video
Convert Video: AVI, MPEG, WMV, MP4, FLV, MKV, H.264/MPEG-4, DivX, XviD, MOV, RM, RMVB, VOB, ASF, 3GP, 3G2, SWF, H.263, H.264, DV
To video: AVI, MPEG, WMV, MP4, FLV, H.264/MPEG-4, DivX, XviD, MOV, ASF, 3GP, 3G2, SWF, VOB,
2. Audio
Convert audio: MP3, WMA, AAC, WAV, FLAC,M4A, AC3, MP2 Format
To audio: MP3, WMA, AAC, WAV, FLAC,M4A, AC3, MP2 Format
3. Image
JPG, BMP, PNG
4. Mobile devices:
iPod, iPhone, iPhone 3G, Apple TV, PSP, BlackBerry, Creative Zen, iriver, Zune etc.
Solution: What’s the BEST of the iOrgsoft video converter ?
the iOrgsoft video converter provide solutions to every specific problem in a very effective way, that means when you get it, you save troubles to buy many other conversion tool. this just the one for all plan.
Convert Video/audio between Almost Any Formats
Video to Flash MPEG converter Video to FLV converter Video to SWF converter, Video to MOV converter, Video to AVI converter AVI MPEG Converter MKV converter
Output Videos to Various Mobile devices
iPod video converter
iPhone video converter 3GP video converter Blackberry video converter Video to mp4 converter Zune video converter PSP video converter Gphone video converter Creative Zen video converter Iriver video converter
1helpful
Uploading a FLV video
Mac Sansa Video Converter allows you to convert all the popular media formats to MP4 video and MP3, WAV, AAC, WMA audio.
inputs:
Video: MP4, MOV, M4V, AVI, FLV, SWF, 3GP, 3G2, MPEG, MPG, ASF, WMV, VOB, MOD, TOD, MKV, RM, DV, TS, MTS, HD TS, HD MTS, HD M2TS, HD H.264, etc.
Audio: MP3, MP2, AAC, AC3, WAV, WMA, M4A, AIFF, FLAC, etc.
Output formats: MPEG-4, MOV, 3G2, MPEG-1, MPEG-2, 3GP video and MP3, WMA, WAV, AAC audio formats.
Top Cyberhome Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
ExpressFiX
ExpressFiX
Are you a Cyberhome Televison and Video Expert? Answer questions, earn points and help others
