Unplug the tv from all devices and unplug from the wall power source. After about 15 minutes, plug ONLY the power cord back in and see if it turns on. If not, than you will need to do a factory reset. With the tv pluged into ONLY the wall outlet ( no cable, DVD or internet connection) Hold the UP arrow on the remote than press and release the POWER button on the tv. This will reset everything and the blinking red light should stop. At this point you should be able to turn the TV on and off.
IF for some reason this does not fix your issue, visit HTTP://esupport.sony.com
Good luck. Welcome to Product Support Get the help you need
go to turn tv on,hear a poping noise,once then tv standby lite blinks 3 times repeatily but no picture or audio.can you help me out with this thank you
i have fixed 3 of this tv, with that exact problem in the last 2 weeks, needs a power supply, you can try to unplug it again, plug it in, hit the power button, as soon as it turns green, unplug it again, after 15 seconds , plug it back in, if power doesnt turn on by itself, turn it on, if it turns red again, emediatily hit power again, may have to hit power a few times in a row, but most of the time you can get it to come on this way, once it is on, it should run ok, until you turn it back off, but not a fix, needs power board
The 7 blinks means that the SC scan drive board might need to be replace but only after checking the voltages from the power supply. If the voltages from the power supply are normal, then proceed to replace the SC scan board. Click here to find the board you need.
If you're using a DVD player or other component using the Component cable hookup, try unplugging that from the mix, unplug the power cord for the TV from the wall and wait 15 seconds and plug it back in, then power the TV back on. Mine used to do this and I gave up on the component cable option and went back to composite (RCA).
