First check the fuse for the blower motor in the fuse panel if it is blown replace it and see if blower works.If still not working you will need to buy a test light from your local auto parts store and check for voltage at the blower motor red wire if the test light shows voltage you might have a bad blower motor. There's a trick to test the motor called the tap test start the car and turn the heater fan on high using a mid size screw driver tap on the blower motor and see if it comes on if it does you need a new motor.
http://technoanswers.blogspot.in/2012/04/how-to-remove-fan-clutch-on-2005-gmc.html
This will help.
Thanks.
