I would like to save my photographs the utstarcom c7076 from a telephone
How may he be? Where I find the necessary program
telephone my service provider Verizon
I ask his help
Peter
The flashing light is probably the Voice Mail
Waiting Indicator. This is triggered by the
voicemail system operated by the Telephone
Service Provider which is a totally separate item
from your phone's Answering Machine System.
Talk to your Telephone Service Provider to
learn how to manage their voicemail. For
some, you are given a telephone number to
dial, a password or number to enter, and a
sequence to follow to play/save/skip/delete
the recordings stored there for you.
If you respond to this note with your specific
make & model number of cordless phone,
we might be able to tell how to reset VMWI
at the handset, but it is still necessary to
manage the voicemail system itself.
The Web Cam works with several different programs, not just the Sony software. Try other Video programs and if that fails to solve the problem; check with Sony Technical services. This company has an excellent service organization and they will walk you through the steps necessary to fix the problem. The Telephone number is listed on the documentation that came with the camera.
Hi Scan the document using Canon PIXMA its very simple follow the mention below instruction to scan to document, picture & email.
Turn on the computer and thescanner.
Open the lid of the scanner andplace the photograph face down on the glass scanner bed. Close the scanner lid.
Click "Start" on the computer.Click "Programs." Double-click "ArcSoft Photostudio 5.5."
Click "File" after Arcsoft programopens. Click "Select Source." Click on the scanner model.
Click "File." Click "Acquire." Thescanner will begin to scan the photograph.
Click "Select Source." Click"Preview." A preview of the photograph will appear on the screen.
Drag the selection box to select theentire photo to scan or a portion of the photo. To crop the picture, click anddrag one corner of the selection box. Adjust the position of the photograph onthe scanner bed if the photo is on an angle.
Click "Scan" to begin the finalscan. The scanned photo will open in PhotoStudio editing window.
Click "File." Click "Save." A "Save Picture"dialog box will open. Type the name of the picture in the "File Name" field.Click on the arrow located on the "Save as Type" pull-down menu to choose theformat of photograph (JPEG or GIF are the usual formats for internet use).Click "Save." The photograph is now saved on your computer.
In order to set call forwarding on this telephone, must first have the feature CFV (Call Forward Variable) on in the line. This feature can be provided by the telephone service provider.
A typical feature code for this is *72 to activate CFV and *73 to deactivate.
You can program these features on the M9316 telephone by do the following:
CFV activate
1) Press the SAVE key.
2) Then select the key where you want to program the feature.
3) Then enter *72 (optional: plus the telephone number of where you want the call to forward to).
4) Press SAVE twice.
CFV deactivate
2) Then select another key where you want to program the feature.
3) Then enter *73
Be sure and label your buttons.
To use go off hook and press the key you just programmed.
1.Start the install process as normal, you will get to the section that asks you to plug in the um100c. Windows will not automatically install these drivers for you. 2.Leave the setup program running and open up Device Manager 3.Find UTStarcom UM100C under unknown devices. 4.Manually search for the driver in "C:\Program Files (x86)\Cricket\QuickLink Mobile\System\driver". After it installs there will be two more unknown devices in Device Manager. Repeat the manual driver lookup in the same location to install them. 5.After that go back to the setup program, you should now be able to click on Next to finish it.
Do you have the Veo Digital Studio Application? If so, double click on the icon for it:
1. Click the Take A Snapshot button on launch your Veo camera.
2. Focus/ adjust as necessary. Use the Small, Medium, and Large buttons to select the desired resolution, then click Take a Snapshot.
3. Click:
a) Retake Snapshot - To take another snapshot *if you don't like the one you took*.
b) Click Save- To save your picture. Select the destination folder and rename the picture if desired. If left unchanged, the picture will be save in the default directory C:\Program Files\Veo Digital Studio\Gallery\Photographs.
Given that consumer telephones are inexpensive, the cost of repairing the speaker phone on the 960 (assuming you still have it) is probably not worth it.
Going off of my memory....to program a speed dial you would first press "Program", enter the telephone number you want stored and then press the one of the memory buttons to save the number to. If the number is to be saved on a lower memory position press "Lower" before you press the memory button.
AT&T's telephone product website has a section where user manuals for many AT&T and Lucent branded telephones.
