1999 Isuzu Trooper Logo
Posted on Dec 19, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
99 isuzu trooper 3.0D difficult to start any morning when the engine is cold, when it does start it has a rough idle and sometimes cut out difficult to start again. both throttle sensors have been changed didn't really work. once engine is warm jeep runs and idles fine. all recall work has been done. any ideas any one?? other than burn it!!!!!! thanks
Anonymous
Level 2:
Legend:
An expert who has written 200 answers of more than 400 characters.
  • Expert 251 Answers
  • Posted on Jun 07, 2011
Anonymous
Expert
Level 2:
Legend:
Answers
251
Questions
0
Helped
76228
Points
272
Engine is difficult to start when cold
  1. Check the battery condition, battery state of charge and starter motor current draw. Replace the battery if marginal and the starter motor if the current draw is beyond specification.
  2. Check the battery cable condition. Clean the battery terminals and replace corroded or damaged cables.
  3. Check the fuel system for proper operation. A fuel pump with insufficient fuel pressure or clogged injectors should be replaced.
  4. Check the engine's tune-up status. Note the tune-up specifications and check for items such as severely worn spark plugs; adjust or replace as needed. On vehicles with manually adjusted valve clearances, check for tight valves and adjust to specification.
  5. Check for a failed coolant temperature sensor, and replace if out of specification.
  6. heck the operation of the engine management systems for fuel and ignition; repair or replace failed components as necessary.
Engine is difficult to start when hot
  1. Check the air filter and air intake system. Replace the air filter if it is dirty or contaminated. Check the fresh air intake system for restrictions or blockage.
  2. Check for loose or deteriorated engine grounds and clean, tighten or replace as needed.
  3. Check for needed maintenance. Inspect tune-up and service related items such as spark plugs and engine oil condition, and check the operation of the engine fuel and ignition management system.
I just bought an 2003 Isuzu Trooper 4jx1 model last month. Lately I started to experience an engine shut-down when ever I try to run it on cold engine. I also notice that it is hard to start when the...
indicates a fuel supply and pressure problem
check and bleed the system
have the injectors professionally overhauled by a diesel specialist shop
Lost power to engine
Check make sure all plugs are firing. Sounds like what my 93 Rodeo was doing-Idled okay but very rough when in gear. Turns out only 5 out of 6 plugs were firing due to a defective ignition module- 100 bucks later it works fine.
Hope this helps.
1helpful
2answers
Have a code p0401 how do u fix it , I know it has something to do with the egr system but I,m not sure where its located on my trooper, engine size is 3.5 v6
I have a 2000 Isuzu Trooper that had a PO401 code that would reset and then 2 miles later the light was on again - I found if you remove the EGR valve and start the engine that the engine should idle rough - If it doesnt and you have vacumn at the intake port spray carb cleaner down the port slowly and see how long it takes for the engine to run rough - Keep spraying till the engine dies and spray some more down the passage and let the engine set for 5 minutes and then restart the engine - it will run rough at first but clear out - you should be able to feel the engine RPM change when you put your finger over the intake vaccumn port for the egr - If not then repeat the cleaning method again - If you do feel the rpm change then put the egr valve back on and clear the code and run your drive cycle to see if it is fixed.
Difficulty to start early morning
I had the same problem, early morning rough idle. I changed the idol control sensor. Real easy part to change, usually about $100 for the part. My engine was teh 2.8 in 1990 Trooper. Hope it helps.
Truck cuts off when put in gear
If its the 4JX diesel engine the crankshaft position sensor wants an adjustment as its going out of range.
7helpful
2answers
Isuzu 2001 diesel engine won't start
cant start deisel 3.0 lilter sounds like there is no fuel getting to the engine
3helpful
3answers
98 Isuzu Trooper stalls on cold start, idle issues..
I had the same issue on my 99 Trooper.
It would usually start when completely cold, but idle around 2k RPM.
It would drive fine. But if I shut it down, ran into a store, and came back out, it would start but immediately idle.
Had to ride the gas a little to get it into gear.
The Check Engine light has been going on and off for 6 months or so.
I took this to my local trusted repair shop (no Isuzu dealers within 200 miles).
The diagnosed the light, and found that the Intake Gaskets were bad or leaking.
The idling problem was related to the car not being able to control the amount of air coming in.
They replaced the Intake gaskets by the next day, and I haven't had a problem since. And no more check engine light, which has been on half a year.
Here's some details from my bill:
(1) Intake Gasket set $107.95
Misc materials $21.00
2.1 hours of Labor
The total cost to me was $345.00, and I definately don't feel gipped.
2answers
Stalls and wont idle when cold
many automobiles behave that way on a cold start, so you don't have to worry about it. just continue to rev the engine until it is warm!
Top Isuzu Experts
ZJ Limited
ZJ Limited
Thomas Perkins
Thomas Perkins
Are you an Isuzu Expert? Answer questions, earn points and help others
