Re: Canon Digital Video Camcorder ZR70 MC DC 7.4V
Is it possible to purchase a power cord to make it possible for me to transfer videos from my video camera to my PC.
If not, how do I transfer the pictures from the video tapes to my computer?
My email is: [email protected]
With Thanks,
Raya
As your camera only has analogue outputs, you will need to buy a video capture card for your PC, such as those made by Leadtek. As mentioned by Tela above, there are also external USB-connected devices that do the same job.
Make sure your PC exceeds the minimum spec or you may lose information during capture. I would recommend at least 1GHz processor.
Hope that helps.
SOURCE: Canon ZR70 MC Mini Digital Video Camcorder...Not ejecting
Typically, the problems of this sort tend to be one of a mechanical nature; In other words, the case may be bent, causing this problem. Does the machine make a "motor noise" as the well opens? And then makes a "binding noise" before coming to rest? This would be a definite cause for your dillema, and a camera shop visit would be in order, unless you have some mechanical aptitude....accordiaman
SOURCE: Cassette removal from dead Canon MV650 Camcorder
I just solved my own problem by disassembling the camcorder until I had access to the little motor which operates the eject mechanism. It sits on the corner of the mechanics subassembly, close to the cassette. By applying about 3.5 Volts DC from a regulated power supply to the two motor contacts, it started to operate (test which direction it needs to go by trying both polarities) and lifted the cassette out of the play position and ejected it. Only since the tape was still wound around the drum, I had to use a thin tool to turn the cassette hub in order to tighten the tape a bit. Then the protective cover of the cassette closed and I could slide the cassette out of the slot by hand. Bingo!
SOURCE: How do I transfer a recorded tape to my computer
You need IEEE (Firewire) or "DV" cable to transfer video from the camcorder to your computer. The connection is "DV" and is located on the front of the camera next to the "S" port. The marketing for this camera was deceiving...most customers thought they could hook up the USB to their computer and upload video...well you can't
SOURCE: need device driver Canon ZR70 MC video camera
Here is the drivers page for your product:
http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=SupportDetailTabAct&fcategoryid=227&modelid=8619#DownloadDetailAct
Hope this helps,
David
If my solution helped please rate accordingly
