20 Most Recent Canon ZR40 Mini DV Digital Camcorder Questions & Answers
Re: Canon Digital Video Camcorder ZR70 MC DC 7.4V
hello, As your camera only has analogue outputs, you will need to buy a video capture card for your PC, such as those made by Leadtek. As mentioned by Tela above, there are also external USB-connected devices that do the same job. Make sure your PC exceeds the minimum spec or you may lose information during capture. I would recommend at least 1GHz processor. Hope that helps.
7/31/2017 5:32:52 AM • Canon ZR40 Mini... • Answered on Jul 31, 2017
2answers
During playback, only seee a blue screen.
kindly rate me if ui have helped u !
i hope ur problem gets solved
6/28/2016 10:27:16 AM • Canon ZR40 Mini... • Answered on Jun 28, 2016
Everything works except the view finder. Both through the eye piece or the display screen,
hi, If EVF and LCD screen not giving picture, check the change over switch inside the monitor hinges clean it with contact cleaner spray, if it is OK, open and check the circuit on the mother board,
2/29/2016 4:08:10 PM • Canon ZR40 Mini... • Answered on Feb 29, 2016
How do I turn on digital effect
Press the DIGITAL EFFECTS and select D.EFFECT from the Digital Effects menu. If needed, you can find a copy of the User Manual on the Canon website: Canon Support Drivers ZR40
6/2/2014 1:58:58 PM • Canon ZR40 Mini... • Answered on Jun 02, 2014
0answers
My camcorder is a Canon ZR - 40. A red flashing
This is more than likely a problem in the cameras tapr mechanism and can be repaired fairly inexpensively. However, it's not a user serviceable problem and will need to be repaired by a qualified service technician.
My name is Rick and I'm a professional repair technician with over 20 years in the business and have repaired many of these. I'm semi retired and work from home with little overhead so I can keep repair costs low. If you decide to have the camera repaired, please click HERE for a directory listing that suits your needs.
If this response has been of any help to you, please be sure and give a positive vote for me on FixYa.com.
6/27/2011 12:31:05 AM • Canon ZR40 Mini... • Answered on Jun 27, 2011
I have a Cannon Camcorder
Tape mechanism problems can be quite complicated. This will require disassembling the camera to repair the tape mechanism and can be done fairly inexpensively. However, it's not a user serviceable problem and will need to be repaired by a qualified service technician.
6/24/2011 4:03:03 AM • Canon ZR40 Mini... • Answered on Jun 24, 2011
3answers
I want to use my
All digital video equipment also has the analog video outputs (either S-video and/or composite video) found on current analog equipment. This means you can play a digital video on a regular TV, or transfer a digital video onto an analog VCR. If you record using a digital video camcorder, you can then copy the video onto VHS or Super-VHS tapes, 8mm or Hi-8 tapes, or any of the broadcast formats such as 3/4-inch or Betacam if the recording equipment has the appropriate input connectors.
I suggest check in this link, the ZR740 User Manual and specifically the Editing Section.
Hope this helps.
5/16/2011 12:56:37 PM • Canon ZR40 Mini... • Answered on May 16, 2011
I can get power to my ZR40, and the blue start up
The CCd Image sdensor has gone bad. This part is no longer available from Canon.
1/2/2011 5:28:43 PM • Canon ZR40 Mini... • Answered on Jan 02, 2011
2answers
My husband owns a Canon
You are in a bit of an unfortunate situation here I am afraid. However, I am going to outline all the possible options you have with this below;
1. Borrow any mini-dv camcorder from a friend or relative for temporary use to transfer your tapes to computer. Once you have trnasferred the tapes onto computer you can use any dvd burning software to transfer the video onto DVD. Nero will work for this or Roxio is another possibility. 2. Take your tapes to a video duplicator in your area and have them transferred to DVD professionally (can be expensive - depending on how may tapes are involved). 3. Buy an inexpensive miniDV camcorder to play your tapes back. This is the best long-term and least expensive option if you have a lot of tapes -- and if you can't borrow a camcorder. The camcorder does not have to be a Canon ZR40 - any cheap mini-dv camcorder will do. However you must make sure that whatever camcorder you buy, the camcorder is compatible with your computers operating system. Example Windows 7 & Vista is not supported by manufacturers on many older camcorders including Canon but they will work with Windows XP. Also Important; Most of these older camcorders use firewire IEEE 1394 to transfer video to computer and not USB. Therefore your computer must be fitted with an IEEE 1394 firewire port for it to work. You need to ensure this level of compatibility before you proceed with the purchase of any camcorder including the Canon. 4. Buy a mini dv player. This is a very expensive option. Sony did make one as an example for around $1500 but even if you could get one of these this technology is regarded as obsolete. Not recommended. Hope this has fully outlined and explained your options. Please do remember to accept and leave a vote for the solution. Many thanks.
12/1/2010 2:46:50 PM • Canon ZR40 Mini... • Answered on Dec 01, 2010
Eats tape
This can be caused by several problems including the transmission gear in the tape mechanism not engaging properly or a defective clutch in the take-up spool and can usually be repaired fairly inexpensively. However, it's not a user serviceable problem and will need to be repaired by a qualified service technician.
If this response has been of any help to you, please be sure and give a positive vote for me on FixYa.com .
11/21/2010 7:25:29 PM • Canon ZR40 Mini... • Answered on Nov 21, 2010
When put into camera mode so I can record only get
This is usually caused by a defective CCD image sensor and can be repaired fairly inexpensively. However, it's not a user serviceable problem and will need to be repaired qualified service technician.
10/31/2010 5:59:54 PM • Canon ZR40 Mini... • Answered on Oct 31, 2010
I have a Canon ZR40. We can't remember anything
The most likely cause for this is a damaged or defective flexible ribbon cable that connects the LCD to the camera body and can be repaired fairly inexpensively. However, it's not a user serviceable problem and will need to be repaired by a qualified service technician.
10/12/2010 4:25:39 PM • Canon ZR40 Mini... • Answered on Oct 12, 2010
After using approx 20% of
This problem is caused by a loose ribbon like connector on the main PCB. When a friend of mine had this problem, I opened it up, unplugged and re-plugged all the connectors, re-assembled and turned it on. Worked like a charm for about 2 days when the problem re-appeared. So I have opened it up and put insulation tape on all the connectors and problem has not appeared ever since. Apparently this is a very common problem on canon camcorders. Some people even reported that bashing it fixed the problem!
http://www.fixya.com/support/t129385-remove_cassette_displays_when_put_in
8/21/2010 3:37:32 PM • Canon ZR40 Mini... • Answered on Aug 21, 2010
Canon ZR40 Mini DV Digital Camcorder Logo
54 questions posted
Top Canon Video Cameras Experts
NOEL
NOEL
Lawrence Oravetz
Are you a Canon Video Camera Expert? Answer questions, earn points and help others
View Most Popular
ZR Canon
  • ZR Canon
Most Popular Question
everything works except view finder
  • Video Cameras
