Minolta magicolor 2200 DeskLaser Printer Logo
Posted on Dec 11, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Minolta 2200 service code 16 - Minolta magicolor 2200 DeskLaser Printer
Level 3:
  • Minolta Master 7,733 Answers
  • Posted on Dec 11, 2010
Minolta Master
Level 3:
Answers
7733
Questions
0
Helped
1865134
Points
21487
(TABP0902037EN00) - magicolor 2200 DeskLaser - What are the steps to fix a service call 16H transfer belt rotate error on a magicolor 2200 series? (TAUS0805552EN00) - magicolor 2200 + - Clearing MC 2200/MC 2210 Status Messages or Error Codes 'ACC_Getstatusr EC;Code=__D, Resetting ACC to Initial State' (q0601101) (TAUS0805008EN00) - magicolor 2 + - Installing CrownNet code on the Crown monochrome printer (q0499042) (TAUS0803976EN00) - magicolor 2200 + - Flashing System Code to DeskLaser to Correct 'Starting System Firmware Image' Message (q0202107) (TAUS0806277EN00) - magicolor 2200 + - Clearing MC 2200/MC 2210 Status Messages or Error Codes 'Toner Missing' (q0800700) (TAUS0806280EN00) - magicolor 2200 + - Clearing MC 2200/MC 2210 Status Messages or Error Codes 'Transfer Belt Missing' (q0800703) (TAUS0806281EN00) - magicolor 2200 + - Clearing MC 2200/MC 2210 Status Messages or Error Codes 'Fuser Missing (q0800704) (TAUS0806282EN00) - magicolor 2200 + - Clearing MC 2200/MC 2210 Status Messages or Error Codes 'Oil Roller Missing' (q0800705) (TAUS0806283EN00) - magicolor 2200 + - Clearing MC 2200/MC 2210 Status Messages or Error Codes 'Toner Low' (q0800706) (TAUS0806284EN00) - magicolor 2200 + - Clearing MC 2200/MC 2210 Status Messages or Error Codes 'Toner Empty' (q0800707) (TAUS0806286EN00) - magicolor 2200 + - Clearing MC 2200/MC 2210 Status Messages or Error Codes 'Replace Fuser Unit' (q0800709) (TAUS0806287EN00) - magicolor 2200 + - Clearing MC 2200/MC 2210 Status Messages or Error Codes 'Transfer Belt Life Low' (q0800710) (TAUS0806288EN00) - magicolor 2200 + - Clearing MC 2200/MC 2210 Status Messages or Error Codes 'Replace Transfer Belt' (q0800711) (TAUS0806289EN00) - magicolor 2200 + - Clearing MC 2200/MC 2210 Status Messages or Error Codes 'OPC Drum Life Low' (q0800712) (TAUS0806290EN00) - magicolor 2200 + - Clearing MC 2200/MC 2210 Status Messages or Error Codes 'Replace OPC Drum' (q0800713) (TAUS0806292EN00) - magicolor 2200 + - Clearing MC 2200/MC 2210 Status Messages or Error Codes 'Replace Waste Toner' (q0800715) (TAUS0806293EN00) - magicolor 2200 + - Clearing MC 2200/MC 2210 Status Messages or Error Codes 'Oil Roller Life Low' (q0800716) (TAUS0806294EN00) - magicolor 2200 + - Clearing MC 2200/MC 2210 Status Messages or Error Codes 'Replace Oil Roller' (q0800717) (TAUS0806295EN00) - magicolor 2200 + - Clearing MC 2200/MC 2210 Status Messages or Error Codes 'Put Media in Input Tray' (q0800719) (TAUS0806296EN00) - magicolor 2200 + - Clearing MC 2200/MC 2210 Status Messages or Error Codes 'Put Media in Upper Bin' (q0800720)
  • Robyn-G May 09, 2011
    Cannot get to web page with the solutioin suggested
C650
scanner home position code. Check the scanner located under the big glass. the scanner also has the exposure lamp. the bright light.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Minolta 2200 service code 14
check the 2nd transfer roller the sponge looking is seated properly?
Minolta magicolor 2200 registration is shifting
Yes,
There is a solinoid on the right side that will cause this to happen. I placed a spacer in mind a resolved the issue. Not an ease fix as you need to put the machine way down but it's a cheap do it your self job.
23helpful
3answers
C03FF Minolta bizhub 210
C03FF, is the improper or unmatched model setting code. go to "service mode" In service mode please select "ADJUST"
in "ADJUST" please select "Model Setting" in "Model Setting" select the cpm, (Copy speed) of your machine, for example if you have bizhub 210, then select "21" from the list. if you have bizhub 163 then select "16" from the list and press "yes" button. code will remove.
Are you there? I have a problem with a Minolta 2200 as to the error about replace the transfer belt . Can you help
contact minolta tech support coz they will tell you how to change the transfer belt if you do not know any thing about printers get profeshinal help
2answers
Paper is coming out folded - accordion-like
Sounds like the fuser is worn out/damaged or maybe your paper is damp.
Magicolor 2200 can't complete warm-up
clean the connectors of the toner cartridge, transfer unit, drum cartridge. did it signal ** toner? replace if needed. check the status of your printer install the printer utility then see the machine status you will see error codes. tell me if what is the code..
Top Minolta Office Equipment & Supplies Experts
Norman Weimar
Norman Weimar
ZJ Limited
ZJ Limited
Are you a Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
