ESQ Quest 07300910 Wrist Watch Logo
Posted on May 23, 2017
I need to find a leather watch strap that fits the ESQ Quest series. These watchs have a longer "prongs" on both side of the dial (the ones that hold the pins for the strap). Thus, using the easily available straps available at most stores leave an unsightly gap between the watch and the strap. OEM watch ******** retail Quest model with leather straps fits perfectly (they are curved and the pin holes are recessed a bit from the top of the strap.. Does anyone know how I can get this strap?
3 Related Answers
Anonymous
  • Posted on Feb 26, 2009
SOURCE: how to change the strap of leather to the gel strap technomarine
What is the reference of the watch? On the Cruise collection, the process is very simple: 1.      (To remove band) Squeeze the easy release spring bar to one side until it detaches from the watch case completely, do the same for both bands.
2.      (To attach new band) Take the straps that you want to put on and squeeze the easy release spring bar with your (nail or screwdriver) and insert into little groove, it should snap right into place
3.      Do the same for other band
If you need more information, please contact us [email protected]
Anonymous
  • 65 Answers
  • Posted on Jul 25, 2009
SOURCE: I purchased an ESQ QUEST watch with a
Ask whoever you purchased it from otherwise I think Esq are made by Movado try chasing them up.
Anonymous
  • 302 Answers
  • Posted on Dec 15, 2011
SOURCE: how to take the buckle off the leather strap from
I will give you the generic answer as I have not actually removed a Cartier buckle. Most buckles use a small bar called a spring bar that goes through the band and "tang". The ends of the bar are like a plunger in that with a small fork like instrument or small screw driver you can collapse the bar and move it out of the clasp. The rest is very obvious. Replacement is the opposite of removal. A fairly simple procedure for most people.
tip
How to exchange leather straps for almost any watch brand
Most of the people are pretty sure that when their watch leather straps are worn out they have to replace them with new ones, made by exactly the same brand as their watch brand is. This is completely wrong. About 95% of all watch brand models can be fitted with leather straps from any watch strap producer without loosing brands identity. All you have to do is: 1. Release the strap from the watch; 2. Measure the width of the strap where the spring bar (pin) goes through and write it down or memorize it; 3. Undo the buckle/clasp; 4. Measure the width of strap in place where the buckle/clasp was fitted and write it down or memorize it; 5. Measure the length of the strap (both parts together) and write it down or memorize it. Now you have everything you need for strap replacement. Visit any shop selling leather straps or even find it on the internet. You will find thousands of different colours, patterns and leather variations. The choice is yours. Just one thing to remember: The strap you are buying must match all the measurements you took of your original strap. This is not difficult to match, as the watch straps usually are made to global standards. When you have your new strap delivered, just fit it to your watch and undo the buckle/clasp that came with it. Fit your old, original buckle/clasp on to the new strap and you are done. Most watch manufacturers impress, engrave or laser engrave their logos on buckles/clasps, not on the leather straps itself. So, when you fit the original buckle/clasp on brand new strap of different make, it becomes the original strap of the watch you own. And nobody knows that the strap is, for example, from Hong Kong, but watch is from Switzerland (except you, of course} as they look together as one nicely designed piece and the buckle/clasp works as the proof of identity. In case if your watch has some unusually shaped fixing for the strap, this shape can be easily cut in to the strap by modellers scalpel. At the very end I just want to remind to all readers: Watch straps sold under watch brand names are 2-10 times more expensive. In fact - they are not produced by watch manufacturers themselves, but in Italy, Germany, China and Hong Kong and then sent to watch manufacturers. Just because these straps were fitted to the watches and the buckles or clasps were added to them, these straps automatically becomes their brand straps and cost a lot, lot more. Hope it helps to save your hard earned money.
on Jan 10, 2010 • Watches
1helpful
How do i tell if my emporio armani watch is real or fake, it has all the right markings has a black leather strap a green face and came in a lined armani pouch
how to tell if armani watch is fake or real,
its near impossible ! its one of the easiest watch to copy,
the movement is much the same, armani use seiko! most copies
are as good has the original, and the time and effort put into making
it are much the same!
Hello where l can find the rubber straps(bracelt) for ESQ BLACKFIN 300m
Thank you for contacting FixYa.
The best place you can contact for replacement would be Movado itself by following the following link:
http://service.movadogroup.com/care.cfm
or you can also try:
http://www.watchbands.com/category.aspx,,categoryID,,754
Best regards. Jewel
Skagen watch band pins I've remove/changed spring pins other watches several times before but for this watch nothing happening How is it done?
they are very tough they have more pressure on them than most spring pins also on your watch they are tucked into the leather very well. the best way is with a spring tool apply quite a bit of pressure. a normal watch band will not fit this watch. it will only take skagen replacement bands.
http://www.skagen.com/service/home.fx
How do i replace the strap with the new one
You can usually but a watch strap from you local shop and they will fit it for you.
If you particularly want a Fossil strap, then you can get one fro them by going to their web site "fossil.com", select "watches", then "men" or "women" and scroll down the page and near the bottom you will find a number of alternative straps that you can buy from them.
You can have it fitted by a local watch shop if you do not wish to fit it yourself.
2answers
Unable to set the date on an ESQ Gentlemen's Quest Big date
pulling the stem to the first click adjusts the date and pulling it farther adjusts the time. pull the stem one click and turn counterclockwise to adjust date. push stem back in after correct date is displayed.
2helpful
ESQ watch parts
Type in your browser: 1) ESQ watch bands
2) EQS watches
3) ESQ watch bracelets
4) ESQ watch parts
Try all of these and you will find numerous sites (too many to list here).
Dec 21, 2008 • Watches
Top ESQ Watches Experts
john h
ADMIN Andrew
ADMIN Andrew
ADMIN Eric
ADMIN Eric
Are you an ESQ Watch Expert? Answer questions, earn points and help others
