Hi, i have a split mural air condicioner Samsung Mh19ZA2-07, with the remote ARH-403, but the remote only works sometimes. Im close to the sensor, the remote have new batteries, etc.... Is possible to reset the remote with the air conditioner unit?
The remote works fine in another unit. Maybe the receiving sensor is the cause. Thanks.The remote works fine in another unit. Maybe the receiving sensor is the cause. Thanks.
You can't post conmments that contain an email address.
The remote itself can be tested--most shops have a simple tester--point remote at it and press any or all buttons and the tester will react---if it tests good the remaining reason is the remote receiver in the actual unit it controls may be bad.
If it is not sending it can usually be taken apart and fixed.
Many Digital cameras will react in a very dark room much like the tester with a faint flash of light when the remote is pointed at the camera you will see a tiny flash on the camera display screen.
E-1 Room sensor and A1 Indoor PCB fault. Please you replace first,indoor sensor and reset.Sometimes indoor pcb shows fault code due to sensor short. After replacing sensor it will show only A! or sometimes no error. If it shows A1, you have to repair/replace PCB. Helpful?
If even with new batteries not working means transmission signal problem. May be with remote or receiving signal problem with indoor. Check your remote with camera mobile and press on/off switch. If it's ultra light flashes, it's o.k. Then repair receiving signal in PCB.If no ultra light in remote, replace remote.
El código P0073 es descrito como el sensor de temperatura del aire ambiente del circuito de entrada de alto. Que consiste en el circuito del sensor de temperatura del aire exterior.
El sensor esta instalado frente al radiador, detrás de la rejilla. Probablemente el problema es que el sensor ha fallado o que el cableado presente algun corto en el mismo o cables deshilachados. Inspeccione los cables y conectores que lleva a la sonda. También
puede hacer referencia a un manual de reparaciones de Jeep Liberty para
obtener información específica, pero también se puede utilizar un
multímetro digital (medidor digital ohmios voltios) para verificar la
ohmios del sensor.
Espero que esto sea de ayuda (recuerde calificar esta respuesta). Buena suerte.
