Mitsubishi WS-55511 55" Rear Projection Television Logo
Posted on Dec 05, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have a red shadow the the right of most images. Been through the standard red and blue convergence settings and appear set properly. I have he service manual and got into the advanced menu to reset tv to default settings. That didn't work either. Any ideas? TIA, Andrew
shaun taylor
Level 3:
  • Mitsubishi Master 1,527 Answers
  • Posted on Dec 06, 2010
shaun taylor
Mitsubishi Master
Level 3:
Answers
1527
Questions
0
Helped
338444
Points
3957
Hello. the red tube has fault you may need a replacement
regards
shaun
Mitsubishi RPTV has a blue shadow/image alignment problem
Projection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
This is a very common failure on these projection sets and a fairly simple DIY fix. All projeciton sets including Samsung, RCA, Sony, Philip Magnavox, Panasonic, Pioneer, Akai, GE, JVC, Toshiba, and others at some point will have the same problem.
Common Symptoms include....
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
  • TV shuts off after powering on. Power light will blink. TV may also make a chirping noise.
Here are some photos of convergence problems.
Here is a quick test....
Using your original remote go-to the settings menu then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move RED and BLUE in all directions - up, down, left, and right. And you should be able to get the grid straight.
If you can't move them in all directions or cant move them far enough your convergence chips are bad and should be replaced. This is a common problem.
Note: If you TV has as flash focus or magic focus button only try pressing the button. If it fails to fix the convergence your need to fix it. See below for a fix
69189a5.pngCONVERGENCE SOLUTION
You will need to replace the convergence chips and possibly some convergence resistors and pico fuses.
This is a a fairly easy DIY job if you are handy and can follow directions. You can get complete repair kits from TvRepairKits.com or click here. They have put together DIY repair kits that include the OEM parts and step by step photo instructions for each repair. If you are not handy or can't follow directions we would suggest calling a shop.
Images on screen have shadows
  • Screen looks 3D
I get a ded line or red underline, or shadow that does not follow
3 d effect is most likely bad convergence Ic---think this set has in the customer menu an option to adjust--if it does go there----if red or blue will not adjust in any direction(up and down or left and right) you need to have both convergence Ic's replaced and then the set adjusted.
Rcs hdtv multiple images
The problem you're having is due to the failure of the convergence amplifier circuit. In that circuit are some components which amplify or control the signals to the dynamic convergence yokes, which line up the red green and blue images to superimpose them over each other to create a proper colour picture. When you get a failure in that circuit, it no longer aligns the images properly, and generally you get what appears to be badly set geometry in multiple colours. In some cases you will also get a problem with the part of the power supply that supplies the convergence amplifiers, or the digicon, which is the digital convergence control module.
Red double picture with green and blue
convergence problem there are 2 integrated circuits inside the set needs to be replaced
2answers
RCA 56 inch hdwidescreen
Did you use the Automatica Convergence to try and straighten it out? If that does not help, you can manually adjust the convergence.
3helpful
Red,Blue,Green Image
YOu have convergence issues. Ok first question. IN your setup menu do you have the convergence option/ if you DO not then it can be a specail fusable link. fl231 if you do. next question do the picture bow in at the middle. if you do then it possibly a convergence power supply issue. next if you go into setup convergence does the crosshairs adjust up or down left to right on both blue and red. I if so then theres is a chance that it can be a convergence adjusment or a amplifer problem AS always THIS SET CAN GENERATE LEATHAL 380 VOLTS EVEN WITH SET UPLUGED SO BE CAREFULL.
Color distortion
There are failures occuring in the scann and convergence circuits. This may not be feasible to service.
Jerry G.
2answers
Tv problem
seems like your tv got convergence problem . try setting up the convergence , use remote . if it does not help you may need to change convergence ic * 2
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Grand Canyon Tech
Grand Canyon Tech
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
