Tengo un panasonic DMR 55 E con el codigo U99 que puedo hacer si alguien me puede ayudar se lo agradecere.mi correo es [email protected]
SOURCE: u99
A U99 error code signifies a general communications failure and is not associated with any specific problem. It
could even be related to the firmware version of your DVD recorder.
Try turning off the power and unplugging off-unplug for at least five minutes before reconnecting.
If U99 reoccurs, you should contact the Global Service Center Network for assistance.
SOURCE: Panasonic Video/dvd player DMR ES30v Fault code U99
Hi,press the power button on the dvd so it goes to standby,then press the power button again to turn the unit on.I hope this helps.Jamie
SOURCE: Panasonic DMR-E30 with U99 fault
Saludos : Yo tenia el mismo problema. Mi dvd DMR-E30 tenia el
mismo problema . Codigo U99 . Y no funsionaba nada.
Entre a la pagina de soportes de Panasonic y baje el Firmware.
Luego lo grabe en un cd ,el cd lo coloque en la dvd y la dvd se actualiso automaticamente. La dvd funciona perfectamente tanto
con DVD-RAM como con DVD-R. Esta solucion la saque de esta
misma pagina fixya . Gracias Fixya. Att. LACF
SOURCE: Panasonic DMR-EX75 EB-S 160Gb DVD
To my knowledge and on most Panasonic UK/Euro models/versions, error code "U81" indicates glitch in the firmware, specifically, on its initial diagnostic mode, the system could not detect "Freeview" signals. The
concern might have been caused by the absence of an incoming TV signal.
Should this hold true, I then suspect that there is nothing wrong with
the Panasonic unit but rather the Freeview service in your location or
configuration/settings of the provider signals or the tuner.
Let me know,if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Error indication u99
After development of the DVD drive and the frame lying under this the cause is nearby a horizontally placed circuit board one Elko 630 uF lid which ones probably lifted presumably is.
