20 Most Recent Panasonic DMR-EX75EB-S DVD Recorder/HDD Recorder Questions & Answers
2answers
My panasonic dvd recorder no longer shows any
there problem with tuner.
2/24/2022 6:36:55 PM • Panasonic... • Answered on Feb 24, 2022
Unlock Code for DVD - DMR-EX75
Sometimes, hitting "1" on your remote when it's loading bypasses the region sector and allows the movie to be played without functionality of menus. If that doesn't work you can either play it on your computer or search for software that'll put the movie onto your harddrive taking region block off and with the right knowhow back it up onto a dvd blank that'll work. Though if you aren't good with computers, the best way is to buy a cheap $20-$50 dvd player that can be remote programmed to be region free or buy your machine from any Chinatown store.
6/29/2020 8:57:25 AM • Panasonic... • Answered on Jun 29, 2020
4answers
Panasonic DMR-EX77 - Error code DVD3
Pan use a version of Linux on the recorder. If you change the hard drive there is a format command in setup to format a new hard drive. Put a DVD in and try selecting and playing both DVD and HHD via the front panel buttons. Sometimes you can get error codes on a unit when the batteries in the remote are low. Try changing them Sometimes the remotes are faulty and not communicating properly. A fix in some cases is to press the number button corresponding to the number shown on the display together with the enter or OK button for at least 2 seconds. Good luck
10/15/2018 7:13:34 AM • Panasonic... • Answered on Oct 15, 2018
SONY DAV DZ260, home theatre. Trouble reading the disc.
There is some intermittent connection that is causing the issue. Finding it might prove to be a bear - I would recommend sending it back for another working.unit.
6/25/2017 8:45:29 PM • Panasonic... • Answered on Jun 25, 2017
U81 is permanently on the
U81 error literally means 'Microprocessor Communication Error on the Universal asynchronous receiver/transmitter'.
This error can be caused by a number of different reasons but one of the most common is a software / firmware problem relating to the Freeview part of the unit.
If you turn the unit off for 30 minutes it should reset the fault.
At this point to need to check what version of firmware you have installed and then check the Panasonic website for your country for the latest version.
4/7/2016 10:17:21 AM • Panasonic... • Answered on Apr 07, 2016
Panasonic dvd recorder dmr-ex75
Change the AV settings on the DVD or TV to be the same format. Feeding AV into an AV-S gives B&W
3/12/2016 1:44:05 AM • Panasonic... • Answered on Mar 12, 2016
2answers
I have an HDD rerecorder that now sjips and freezes
HD takes more info and if you don't have a fast enough processor to handle this, that might be the problem.
The age of the recorder would tell you that. If it's 3 years old that might be it. Also how can the recorder record the HD signal unless it has the right tuner??
4/19/2015 10:05:36 PM • Panasonic... • Answered on Apr 19, 2015
My free view box will not pick up Internet
Probably because it does not have WiFi built in.
2/15/2015 7:37:41 AM • Panasonic... • Answered on Feb 15, 2015
What does U81 mean
It could mean there is a fault on one of the circuit boards. See http://www.avforums.com/threads/panasonic-dmr-ex75-85-u81-error-repaired-solved.1486954/
8/29/2014 6:09:07 PM • Panasonic... • Answered on Aug 29, 2014
0answers
I have an error code HDD ERR
When your HDD (Hard Disk Drive) does not work, the computer would like a recovery disk, or with windows the Windows disk will do. If only the OS has some damage windows will see so and ask, should I recover the OS already on the HDD. If you choose that opting, the CD will try to recover everything. If your HDD is really defect and can't be recovered by the OS, toy have to replace the drive and setup the computer again. You have lost all data and all program m's on the HDD, so I hope you have a backup of at least all your data. Good luck
7/21/2014 11:01:55 AM • Panasonic... • Answered on Jul 21, 2014
Panasonic DMR-EX75EB-S DVD Recorder/HDD Recorder Logo
178 questions posted
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Jaime Hernandez
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Panasonic Televison & Video
Most Popular Question
unlock code dvd dmr ex75
  • Televison & Video
