Take the laptop apart techgeek564.
You Definitely do Not want it roaming around in there, to short out the laptop.
Here is the Service Manual, (Free),
http://www.tim.id.au/blog/tims-laptop-service-manuals/#toc-toshiba
Go to the 11th line down.
The one that starts with > Satellite A10
In this listing of files go down to the second line, (Starts with > C650D), and then go across to >
L450. Click on L450.
[The Toshiba Satellite L455-S5989 is part of the Toshiba Satellite L450 series ]
After you click on L450 it will take about 5 seconds to see the first page, and additional time to fully download.
(Took 45 seconds for me just now)
Suggest you let the file download all the way before looking through it.
You are not permanently downloading the file. If you want to save a copy to your computer, and do not know how, post in a Comment.
[This way you won't have to download again. You can also burn a copy of to a CD disk for safekeeping, and having access anytime you want.
Further, you can delete the file from your harddrive after burning a copy, and save harddrive space ]
A) ALL power removed from the laptop. AC adapter (Charger) and Battery.
B) Buy and use an ESD wrist strap. Connect the alligator clip to a good ground source.
(Electro Static Discharge)
Your body carries Static electricity, and Static WILL fry out (Short Circuit) the hardware components inside a computer.
The ESD wrist strap will relieve your body of Static, and safeguard your laptop from Static shock
Average price of an ESD wrist strap is around $3 to $6. Much cheaper than a new laptop.
C) Use a multi-compartment container for the various screws you will remove.
Mark each compartment for the area the screws come out of.
There may be as many as 60 screws, and 12 different types.
Do Not mix them up!
You can use a clean egg carton, and mark the egg holders.
D) Make a record as you disassemble. Make drawings and notes. Use a camera, or videocam if available.
(Use Good lighting)
It's nice to have a record to refer back to in case you get interrupted.
You may find this information to be helpful also,
1) http://www.irisvista.com/
2) http://www.irisvista.com/tech/laptops/Toshiba-Satellite-L45/laptop-disassembly-instructions-1.htm
[You are on Page 1. Page 2 and 3 links are on the Top, or on the Bottom of the page in white.
Page 1::Page 2::Page 3::Find another model ]
IF you need ANY guidance, please post in a Comment.
Regards,
joecoolvette
