Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis.
To some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board [SMPS]. In such cases, the power supply board might need replacement. To some models sets, the back-light inverter and SMPS section circuit will be integrated at its main board itself. If so; the main board should be replaced. To some models of sets, all these section circuit will be integrated at its main board. If this is the case, you have to replace the main board.
SOURCE: visio l32 hdtv
here is some info:
FREE Lifetime Technical Assistance:
Quality service and FREE LIFETIME technical assistance are integral parts of VIZIO's commitment to our customers.
Technical Support via Email:
You can reach our Technical Support Department via email. Please include the following in your email: Email: [email protected]
VIZIO Technical Support agents are available to assist you via telephone during the hours listed below:
Technical Support Hours:
Monday ~ Friday: 6:00 AM - 6:00 PM Pacific Standard Time.
Saturday ~ Sunday: 10:00 AM - 2:00 PM Pacific Standard Time.
Technical Support Phone: 714.668.0588
SOURCE: Directv Tivo recorder no remote programming code for Visio 37''
If it were a Tivo series 3 you might have better luck with it.
http://www.tivo.com/setupandsupport/technicalsupport/compatibilityhelp/Using_the_Learning_Feature_of_the_TiVo_Glo_or_Series3_Remote.html
I've had my series 2 Tivo for about 2 1/2 years and never found the correct codes for it. I think it works off of a list of TVs manufactures about 3 years ago.
SOURCE: How to clean the screen of our 42
Vizio TVs come with a cloth to remove dust and fingerprints. If you don't have that anymore, any lint-free cloth should do. If any smears are stubborn, dampen the cloth, then wipe clean.
Never use household cleaning solutions on your screen. Some chemicals can damage plastic.
SOURCE: 47" two yr old Visio
This is the second time I have seen this problem this week. Seems like a common issue on Vizio LCDs. Anyways the problem you mentioned indicates that the tv-micro IC has failed. THis is located on the main audo/video board and a component level repair is not possible in this case. The main A/V board has to be replaced and it should cost you around 100-125$. Would you like to do it yourself?
SOURCE: Visio model sv320svt will not
Hi after the logo flashes does it turn off completly or do you see the power light still on or any other lights?
