Hair Care Tips: General A healthy lifestyle will mean healthier hair for you. Excessive stress, smoking, not exercising and not eating nutritiously are not healthy for your hair. Get enough sleep. Hair Products (Gel, mouse, hair spary...) Avoid using hair styling products with alcohol which dries out hair. Avoid puting hair styling products directly on your scalp, if you put it on your scalp you'll clog the pores on your head. Swimming Before entering a pool, wet your hair so your hair will soak up the initial water instead of the chlorinated water. When swimming where a cap to protect your hair from chlorinated water, if you choose not to wear a cap make sure you shampoo and condition your hair right after you are done swimming. Drying Hot air can be damaging to your hair so when using a hair dryer use the cool setting. Don't leave the blowdryer in one spot for more than a few seconds, keep it moving and at a good distance away from your hair. To speed up the drying process, pat your hair dry with a towell and let the remaining moisture in your hair dry naturally. Gently use your fingers or a pick to untangle any knots while your hair is drying.
