SOURCE: car stereo wiring diagram
Only Wharfedale that I found was a UK company for loudspeakers. Sorry, but you need to me a little more specific with your request.
Chris
SOURCE: 2001 Hyundai Accent 2 door coupe stereo wiring diagram
should be on the back of the amp mine is
SOURCE: Wiring harness
you should never cut the wires on your factory harness... metra and other companys have harnesses that fit your car and would provide you with a correct wire color code you need to hook up a aftermarket stereo keep that in mind but i will post the wire diagram u are looking for
SOURCE: Replace 2005 Nissan altima stereo receiver
Try radio shack, or stereo sales/installation place for ready to go plug adapter. For a few bucks, it saves headaches, and butchering the wiring in case you want to re-install old one later when trading in or selling the car.
SOURCE: 2002 Taurus stereo
Here are the factory wire colors, please rate this solution to your problem, a note any stereo store that sells auto decks has adapter wiring harnesses to do a direct plug in of your DIN standard radio you are trying to install, no cutting of the factory harness, they are cheap
2000 Ford Taurus Car Radio Stereo Wiring Diagram
Car Radio Battery Constant 12v+ Wire: Green/Black
Car Radio Accessory Switched 12v+ Wire: Black/Pink
Car Radio Ground Wire: Black/Green
Car Radio Illumination Wire: N/A
Car Stereo Dimmer Wire: N/A
Car Stereo Antenna Trigger: N/A
Car Stereo Amp Trigger Wire: N/A
Car Stereo Amplifier Location: N/A
Car Audio Front Speakers Size: N/A
Car Audio Front Speakers Location: N/A
Left Front Speaker Positive Wire (+): Orange/Green
Left Front Speaker Negative Wire (-): Blue/White
Right Front Speaker Positive Wire (+): Tan/Green
Right Front Speaker Negative Wire (-): Green/Orange
Car Audio Rear Speakers Size: N/A
Car Audio Rear Speakers Location: N/A
Left Rear Speaker Positive Wire (+): Gray/Blue
Left Rear Speaker Negative Wire (-): Brown/Yellow
Right Rear Speaker Positive Wire (+): Black/Violet
Right Rear Speaker Negative Wire (-): Orange/Violet
