SOURCE: Amana ALE643RAW Gas Dryer
.hi with gas dryers the parts to look for are . the blower . will take longer to dry and noisy .The venting very important. The coils on the gas valve .Will cause the flame to only come on for a few minutes . then nothing so for that problem . replace the coils. Thanks the appliance doc
SOURCE: Gas dryer continues to run on the Auto cycle.
try to get the manual for the dryer you got and locate the moisture sensor if this sensor is bad what happen is that the automatic timer thinks that the clothes still wet and continues to dry once the sensor detects no moisture then it shut off the dryer normally is located behind the dryer on the exit line of the air duct and tested for conductivity and see if is good or not
SOURCE: It ignites but does not heat hot enough to
take the exsaust off the back of the dryer and run a load with it dettached and see if this makes a difference and let me know
SOURCE: my dryer seems to take forever to dry the clothes.
you me have a problem with your venting, make sure it is not kinked or blocked outside by a bird nest
