20 Most Recent GE Clothes Dryer 5 Cycle Timer - WE04X10073 Questions & Answers
Could be a belt that is slipping.
GE Clothes Dryer... | Answered on Mar 07, 2016
with no testing we can not tell sorry
GE Dryers | Answered on Nov 16, 2020
Control Lock / Child Lock issue. Taking longer to dry is because air flow is compromised. It needs a good clean out, especially at the rear where the pipe and outside vent is.
https://www.justanswer.com/appliance/8gcx0-ge-profile-dryer-i-m-getting-cl9-error.html
On this unit, the error code CL9 indicates the child lock feature is activated. Press the temp and and time buttons and hold them for 3 seconds. This should reset the child lock and clear the code.Mar 27, 2019
i just purchased this new samsung dryer and when - Q&A ...
GE Dryers | Answered on Oct 28, 2020
usually 2 screws on each side bottom front, and possibly 2 in under dryer vent screen. front panel should drop off. for the top there should be 2 screws at the top on both sides just under the lid. you can slide belt off and pull drum out
GE Dryers | Answered on Aug 26, 2020
See if any troubleshooting steps apply in page 21 of the free online manual below. Verify electric circuit breaker in your home is not tripped off.
https://products.geappliances.com/MarketingObjectRetrieval/Dispatcher?RequestType=PDF&Name=49-90497-3.pdf
May want to contact vendor GE for support.
https://www.geappliances.com/appliance/GE-7-0-cu-ft-capacity-gas-dryer-with-steam-GFDS140GDWW
GE Dryers | Answered on Jul 08, 2020
Sears Parts Direct has the parts diagrams here: https://www.searspartsdirect.com/model/4t4uf181o5-000432/ge-dpgt750gc2pl-dryer-parts . The dryer safety thermostat is part 757 on the drum, blower and motor diagram. There are several other thermostats and temperature sensors in the dryer as well.
I hope this helps. Sometimes the safety thermostat will trip if the dryer vent is clogged or doesn't open properly.
GE Dryers | Answered on Jun 28, 2020
Appears to be the same or similar model number:
Similar model number:
https://www.manualslib.com/manual/57200/Ge-Ge-Profile-Dbxr463gbcc.html
https://products.geappliances.com/appliance/gea-specs/DBXR463EBCC
GE Dryers | Answered on Feb 20, 2020
Jeff,
If your centrifugal switch is bad, more than likely you are going to need a new motor because those are built into the motor. The only other thing to check is to find out if you are actually getting power down to the motor. If you are, then motor problem, if not, then something else is bad that is not letting the current get to the motor. If you can find your wiring diagram, you should be able to find which wires deliver the current to the motor and you can back track to see where you lose the current. Hope this helps!
GE Dryers | Answered on Dec 15, 2019
i don't know. dryer usually has 2 - 30amp fuses or circuit breakers. test or reset both. sometimes faulty door switch stop unit from starting.
https://www.hunker.com/13410586/where-is-the-thermal-fuse-located-in-a-ge-dryer
GE Dryers | Answered on Oct 31, 2019
i don't know. hook up should have been by a qualified installer and properly inspected and tested.
be very careful. your unit may be under warranty. please inquire about a free service call before using it again.
dryers blow air to the outside so it vents to the outdoors whenever it is running. there may be a small leak and the odour cold be vented which would account for no odour.
be safe and update your home's insurance.
GE Dryers | Answered on Oct 30, 2019
The heating element is faulty , I don't know if parts are available,some times repairs are worth more than a new unit please check.
GE Dryers | Answered on Sep 15, 2019
I DON'T KNOW ABOUT YOUR MACHINE.
I HAD TO TAKE THE FRONT PANEL, INCLUDING THE DOOR, TO INSPECT A DRYER BELT RECENTLY. IT
SEEMED I COULD HAVE REPLACED A BELT IF I HAD TO. CHECK TO SEE IF YOU NEED A BELT OR IF YOURS NEEDS ADJUSTING AT BELT TENSIONER/
SAFETY SWITCH. YEARS AGO, I MANUALLY TURNED OUR OLDE DRYERS DRUM, THE WRONG WAY FROM
INSIDE THE OPEN DOOR. THE DARN BELT CAME OFF THE TENSIONER. THIS MAY NOT BE A PROBLEM WITH CURRENT DRYERS.
GE Dryers | Answered on Aug 30, 2019
GE Clothes Dryer 5 Cycle Timer - WE04X10073 Logo
1 questions posted
Top GE Dryers Experts
gbob59
Marvin
Marvin
Are you a GE Dryer Expert? Answer questions, earn points and help others
View Most Popular
GE Dryers
  • GE Dryers
Most Popular Question
dryer heats but tumbles slow
  • Dryers
