HP 530 Notebook PC Logo
Posted on Nov 20, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I am having hp 530 laptop with intel core duo inside,512mb RAM,80 gb hard disk.I want to upgrade my processor,ramand hard disk. can i do it ? upto what limit ?
Anonymous
Level 3:
Brigadier General:
  • Master 4,044 Answers
  • Posted on Nov 20, 2010
Anonymous
Master
Level 3:
Brigadier General:
Answers
4044
Questions
0
Helped
1244524
Points
12252
Unfortunately I would have to say no, you won't be able to upgrade the processor. I located a user manual at
http://h18000.www1.hp.com/products/quickspecs/12722_na/12722_na.PDF
According to specifications you can increase the Ram to 2 MB and the hard drive should be a 120GB hard driver Sata
System Memory 1024-MB 533/667-MHz DDR2 SDRAM in one slot
Two SODIMM slots; supported memory 2048 MB2
Operates at a maximum of 533-MHz with 667-MHz memory
Hard Drive 120-GB3 5400 rpm SMART SATA
The processor will be limited to what the motherboard can support and it was designed for that 1.6 Ghz processor. Unfortunately it is very difficult to upgrade processors in laptop machines. I do have to ask how old this machine is. The specification indicates MegaBytes of ram and this is actually very little Ram in today's computing world. Most machines support at least 2 gigaBytes of Ram to start with.
Help!sys32 driver files corrupted/lost?
If you have a repair disk try inserting that and choose system repair option
I WANT TO UPGRADE MY SYSTEM .MY SYSTEM SPECIFICATIONS ARE: RAM: 512MB DDR2 SAMSUNG RAM HARD DISK: 80 GB PROCESSOR : INTEL PENTIUM 4 @ 3.20GHZ CAN YOU SUGGEST ME THE BEST OPTIONS THAT CAN SUIT THIS...
The frist thing to upgrade is the amount of RAM you have. All the newer Microsoft opering system requier at lease 1Gigabyte of Ram to work.. After that consider upgrading you hard disk drive.
1helpful
My Wifi is not working. My laptop sound is scratchy. I want to upgrade my processor from celeron to core 2 duo which one i should select for cpu upgrade?
Two main things to know before you can attempt a Processor upgrade.
1) What Processor socket is on the motherboard?
2) What motherboard chipset is on the motherboard?
(Northbridge and Southbridge chip. Unless it's a motherboard that supports Intel Core 13, Core i5, Core i7, and Core i9 processors)
According to specifications I found online just now, the BenQ Joybook A53 comes with an,
Intel Core2 Duo T7250 processor,
http://laptops.techfresh.net/benq-joybook-a53/
Scroll down.
(Only 512MB's of DDR2 Sdram (SO-DIMM) ram memory that operates at 667Megahertz?
{ PC2-5300} Yecch! You need at LEAST 1GB of ram memory. (512MB + 512MB = 1GB.
2GB would be best)
http://www.laptop-software.com/benq/benq-joybook-a53-features-and-specifications/
Information on the Intel mobile Core2 Duo T7250 processor,
http://en.wikipedia.org/wiki/List_of_Intel_Core_2_microprocessors#Core_2_Duo_2
Scroll the page down until in the left column you see T7250. Then read across, and match the headings above.
Uses a Socket M processor socket,
http://en.wikipedia.org/wiki/Socket_M
Is your problem directed to a BenQ Joybook A53 Notebook PC, or is it another model?
1helpful
3answers
Hi!! i have a hp 530 laptop with the following spceification intel core(tm) duo cpu ,t2400 @1.83ghz, 987 mhz,504 mb of ram. I need to know what is best possible upgradation for my laptop and i need to...
To improve performance, increase the RAM from 512Mb to 1Gb or 2Gb.
The graphics card is part of the motherboard and therefore cannot be upgraded, BUT the graphics card used shared RAM (part of the main RAM) and you most likely can increase the video RAM by configuring the video RAM from the BIOS configuration.
2helpful
Can I upgrade my CPU to an Intel Core 2 duo 1.7
You are basically limited to what was optional on the model. So you can only upgrade to one of the following cpus:
Intel Pentium M 745 (1.8-GHz) with 400-MHz front
side bus (FSB)
Intel Pentium M 735 (1.7-GHz) with 400-MHz FSB
Intel Pentium M 725 (1.6-GHz) with 400-MHz FSB
Intel Pentium M 710 TJ85 (1.4-GHz) with 400-MHz FSB;
operates at a lower temperature than other processors
Intel Celeron M 340 (1.5-GHz) with 400-MHz FSB
Intel Celeron M 330 (1.4-GHz) with 400-MHz FSB
And you are limted to 2gb of ram max on this model.
My 40 GB hard disk got crashed for KOB 810e FST Mother board. can i use new 80G or 160 GB hard disk. does my mother board supports 80 GB or 160GB hard disk. I have 256 MB of RAM. can i upgrade it to...
Yes, any motherboard that supports "larger-than-32GB" disk-drives should support larger disk-drives.
Yes, most motherboards support up to 512MB per stick of RAM.
5helpful
2answers
Upgrading My hp530 laptop
It is working.
Tested first with one new module with 2GB RAM, then with 2 modules, 2GB (new) + 1GB (original). Post and Windows are showing 3GB.
The HP 530 notebook is working OK.
I want to upgrade my hard drive.
If you have 50% or more disk space free then you may not need a larger hard disk at this time. If you have 512Mb of RAM, you can get better performance with 1Gb or better still 2Gb of RAM if your Acer can support more than 1Gb of RAM.
Cpu upgrade
You can upgrade your pc to intel chipset original motherboard...and do it to intel core 2 duo processor. if u want to upgrade ur ram then go for 1GB ram... and 250 GB hard disk and finally go for pentium-IV and dvd writter... and use microsoft mouse and keyboard bcoz it does not require driver to be installed
Top HP Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
