Hello Robert - From what you have described, it seems like you may be referring to the perimeter hot tube. It is normal to be warm to the touch; however, since it may feel hot to you, I would suggest verifying that you have the proper clearances around the refrigerator. You can refer to your owner's guide for those specifications. If you do not have an owner's guide, you can download one at the manufacturer site. If the clearance is fine, you may need to clean the condenser coils. As part of routine maintenance, you can remove the toe grille (located at the foot of your refrigerator) by unsnapping the sides and lifting outward towards you. Now, using an extended vacuum attachement and condenser cleaning brush, remove dust buildup from condenser coils on left side underneath refrigerator. Cleaning condenser coils typically resolves this issue. But, if clearance is fine and the condenser coils are free from dust and you are still feeling too much exterior heat, you may need to check with a local service tech to determine what else could be causing this issue.
