Computers & Internet Logo
Posted on Sep 21, 2010
My ata 40 gig hdd after installing xp on aformatted drive.every time i run chkdsk it says i have problems that chkdsk can fix,but never dos.
Anonymous
Level 1:
New Friend:
  • Contributor 7 Answers
  • Posted on Sep 21, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
7
Questions
0
Helped
1550
Points
32
Click start and run
type cmd and press enter
type the following line replacing z with your yor har drive letter
chkdsk z: /f/r/x
you should get a message saying it will check on the next system restart, say Y, then restart your system
When it boots up just before it goes into windows it will check and repair.
1helpful
2answers
Unmountable boot volume
If your notebook came with a Windows installation disk, you can fix the issue this way:
1. Insert the installation disk into your CD/DVD drive, and boot up your computer.
2. At the Welcome screen, hit the R key on your keyboard. This will launch Recovery mode.
You should now see a DOS prompt on your screen.
3. Type chkdsk /p and hit Enter. This will launch a utility that scans for hard drive errors.
The process may take some time, so be patient and allow it to do its job.
4. After the chkdsk is done, type fixboot and hit Enter to repair any damaged boot files which may have become corrupted. When prompted to choose "Yes" or "No," type Y for "Yes."
5. Type exit and press the Enter key to reboot your computer.
Assuming chkdsk was successful in fixing the disk errors, you should now be able to boot back into Windows.
If you do not have a Windows installation disk, but have access to another computer with a CD/DVD writer, you can download Hiren's Boot CD to help fix your corrupted boot drive.
1) Download the Hiren's disk image, and follow these instructions for burning the boot CD.
2) To ensure your system boots from the CD you've created, follow these instructions on how to set your BIOS to boot from CDROM.
3) Alternately, you can download a free utility that will create a bootable USB flash drive containing all of Hiren's tools. The above link also provides step by step instruction on creating a Hiren's USB drive, as well as how to set your BIOS to boot from it.
4) Boot the problematic pc from either your Hiren's CD or Hiren's USB drive.
5) Once you've successfully booted your system using Hirens, you will see a menu with a variety
of tools and utilities. Navigate to the hard disk tools menu, and run HDD Regenerator.
You'll need even more patience this time -- as HDD Regenerator is a bit more comprehensive in its error scanning than chkdsk. On the bright side, HDD Regenerator has a reputation for repairing disk errors that chkdsk was unable to.
Good luck, and I hope this helps!
2answers
Hi just installed Windows XP Pro on a Dell Dimension 3000 with 1 gig RAM. This machine was running W2000 pro with no problems. But after formatting the drive and installing Windows XP pro and all updates...
Well you definately tried everything I would have sudgested.
It sounds like the Hard drive is near the end of its life.
If you have only just installed windows, it may be worth getting a new drive, installing your OS on that, you could then use the other drive as extra storage.
I have had a few HD that started to fail. Maybe the format and installation pushed it over the edge. You could always run maxtors drive check tool to see if it can detect a problem.( maxtor is now seagate)
http://www.seagate.com/www/en-us/support/downloads/seatools
3answers
How to fix faulty hard drive?
Are you able to detect the hard drive in BIOS and windows? If yes format it and run scandisk/chkdsk to fix.
2answers
My external hard drive does not show up when
in run windows type cmd and press enter
you will be in dos mode in that go to e:\ and press enter
in e:\ drive type the command chkdsk /r/f and enter
it will says to do later on press y and exit
and restart the system .it will fix the problem
1helpful
2answers
What type of hdd does a HP omnibook 6100 F3260KT support and can it hold more than 30 gig standard factory as current HDD heads are locking up
The type of hard drive you want is a 2.5 inch IDE (ATA) hard drive.
As for the HDD capacity I've worked on an Omnibook 6100 which had a 100GB hard drive so i expect it can possibly take up to 320GB but don't quote me on that.
Regards.
3helpful
2answers
Hard disk not detecting
It is very likely that your motherboard is not capable of handling large HDDs. Too bad, friend. Use a smaller one, or may be two of them.
2answers
Insataling windows xp problms
If u just want XP . Source a dos boot ( u can get files from internet), format the HDD .create main partision for windows xp and try installing
2answers
Query regarding maximum capacity of motherboard support for a hard disk
your cpu does not have much to do with the hdd you may be getting...
technically you should have no problem by getting the largest hdd you can afford. what you may want to take into consideration besides your budget is:
what os you're using.. dos, win9x, xp, vista?
a. if you have dos the smaller you can get probably the better as you may not be able to create a large partition. (chances are you may not get anything new smaller than 40 gigs.. and that would be a big waste of money and hard drive room)
b. if you have win9x, your probably using fat32 for your filesystem meaning you may not be able to go above 32 gig when creating your partition and formating your drive.
c. if your using win xp or vista... and your planning on using NTFS when partitioning the drive instead of FAT32...(as you should unless your operating system is on a FAT32 partition) you can go for the largest hdd you can afford.
Grand Canyon Tech
Grand Canyon Tech
