Yamaha Mg102c Stereo Mixer Logo
Posted on Sep 19, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My Yamaha MG102C mixer worked fine until recently. Now most of the time , the volume drops away and then comes back every 20 seconds or so..any idea what this could be?
Fred Yearian
Level 3:
  • Yamaha Master 5,603 Answers
  • Posted on Sep 19, 2010
Fred Yearian
Yamaha Master
Level 3:
Answers
5603
Questions
Helped
2250548
Points
16163
I would suspect the power supply regulator MAY be thermally shutting down and then cools and restarts.
The 20 second interval almost has to be thermal to get the delay.
Psr s670 keyboard plays fine but when it is plugged into a mixer after a time the volume kicks in and out?
The issue you are experiencing could be related to a few different things. Here are some things to check:
  1. Check the cables: Make sure the cables you are using to connect your keyboard to the mixer are in good condition and securely plugged in. Sometimes a loose connection or a damaged cable can cause issues with the volume.
  2. Check the mixer: Make sure the mixer is set up correctly and the levels are adjusted properly. If the mixer is overloaded, it can cause issues with the volume.
  3. Check the keyboard settings: Make sure the keyboard is set up correctly and the levels are adjusted properly. Some keyboards have settings that can affect the volume output.
  4. Check for interference: Sometimes interference from other electronics or electrical sources can cause issues with the volume. Try moving your setup to a different location and see if that helps.
If none of these solutions work, it may be a hardware issue with either the keyboard or the mixer. In that case, it may be best to consult with a professional technician.
Mar 28, 2018 • The Music
What is the best way to connect a Yamaha MG102c to a Canon Xha1s?
It could be the type of cables you're using. Are they balanced or unbalanced?
The jacks on the end will tell you what type of cable it is.
If the metal jack (plug) has 2 circles, it's a three-conductor plug (TRS or "tip-ring-sleeve"), which means the cable is balanced. It's meant for stereo connections.
If there's only 1 circle, the plug is two-conductor (TS or "tip-sleeve"), meaning the cable is unbalanced. It's meant for mono.
There's a 3rd kind, (TRRS "tip-ring-ring-sleeve). It has 3 circles, which makes it a four-conductor plug. The extra ring is specifically made for microphone connections in 1/8 in. This is the one you would want to use for a cellphone connection, for normal operation.
But because of what you're doing, the connections and cables have to have to be specific, otherwise you'll end up with lots of noise and interference. It's much easier if you have pictures to look at, that way it won't seem so overwhelming.
This should be able to help. If not, just let me know and I'll do what I can to help you figure it out another way.
TS TRS TRRS TRRRS Combating the misconnection epidemic by Allan Tpper...
1helpful
Just purchased the mg102c, must I utilize a balanced cable to hook up my JBL powered speakers.
Yes... to get best noise performance use balanced TRS or XLR. ALSO power the speakers and this mixer from the SAME receptacle to avoid ground bounce and possible damage to the units.
My Yamaha MG102C has no sound, and all of the LED's are on. There's no inputs connected at all.
Correct me if I'm wrong, but if you have nothing connected as an input, you're NOT going to hear anything. I assume you can't get your inputs to get to main output fader(s), if that being the case, first make sure your gain knobs are up at about 12 o'clock position, your channel faders are up to 0 and then make sure "channel assignment buttons" are assigned to stereo outputs.
Wound the yamaha MG102c be good for a small duo or solo
Use either an amp OR powered speakers. Make sure you use balanced lines to the external amp or powered speakers and power those from the SAME receptacle source as this mixer and any pwered devices connected to it for safety of the system.
The mixer is strictly a mixer. You would need to amplify to drive speakers. Used as a mixer it is fineand would support up to 4 mics.
It does have phantom power for use with condenser mics if needed.
Please use balanced lines (TRS) when connecting to the external amp.
3helpful
3answers
How do i connect yamaha mixer to pc or yamaha receiver
I am sorry to disagree, but some information in the previous post is INCORRECT. DO NOT connect the output of the mixer to the MIC input. The mixer generates LINE level output that should go to the LINE-IN on the sound card. If you connect the mixer to the mic input, you will damage the sound card. MIC level inputs have an additional amplification stage.
Dan
Price for yamaha mg102c
Look on eBay to get rough idea of value/street price.
I need to know where you plug the guitar cord into the mixer
you plug it in to any channel you want just lick a mic.
there you go DFD
I have behringer xenyx802 Iam urgently looking to buy a wireless headphone and mic for my mixer and skype which I use for podcasting. The headet must be padded both ears and mic over mouth due to me being...
Here is a link to what your looking for,
http://pro-audio.musiciansfriend.com/product/Yamaha-CM500-Headset-with-BuiltIn-Microphone?sku=245012
I can't tell from the add but hopefully it comes with adapters for both plugs that will work on your mixer. It does have the one for the headphones but the one for the mic is not clear, they are not interchangeable.
You would obviously plug the headphones into the headphone jack. The knob labeled "Phones/Control Room" will control the volume without changing what's being broadcast. What you hear in you phones is exactly what you are broadcasting.
The microphone needs to go into either mono channel 1 or 2. The adapter for it needs to be a mono Tip/Sleeve adapter as the more common stereo Tip/Ring/Sleeve adapter may cause some problems. You can tell the difference by looking at how many sections are on the plug divided by a little black line. Two sections is mono, three is stereo.
Adjust you microphone level by setting the volume knob, the one on the very bottom, to the 12 o'clock position. Then turn the gain knob, the smaller plastic one on the very top, until the desired volume is reached. If you experience any clipping or distortion turn the gain knob down until it goes away. These are general settings, you may want to experiment until you get the best level without noise.
Top Yamaha Music Experts
Paul Bade
Are you a Yamaha Music Expert? Answer questions, earn points and help others
