Philips SAA7130 TV Tuner/FM Radio/Video PCI Capture Card (683728017118) Logo
Posted on Sep 17, 2010
I have the drivers i just need the software to run the tv card
Anonymous
Level 1:
New Friend:
  • Contributor 22 Answers
  • Posted on Sep 17, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
22
Questions
Helped
3803
Points
59
If you have Windows Xp Media Center Edition, Windows Vista or Windows 7, use Media Center to use it.
Help to install dvb tv card after full recovery installation of windovs xp. all drivers and software are installed, but the tv card 63gxm4101-10 doesnt find the software. the tv card is an express card...
you must RUN the software diagnostic coming with your computer or downlad from your supplier website in order to get the support and fix it. You need to install and download the driver for tv card.
God bless you
3answers
Connecting Virginmedia TV settop box to PC using Philips TV capture card. Result - sound and picture BUT black & white!!
You are either running NTSC into a Pal system or the other way around. Check the setup menu on the Virginmedia box to make sure what it's running, then make sure the TV card is running in the same format.
Hope that helps =)
I can access the TV on my pc even after pluging in the tv card the tv cars SAA7130HL PC TV PCI/7130 PAL TV FM
check your tv card driver that it installed perfectly or not.
and after it check your software of tv running. that it is compatible with your tv card. if not then install your software of tv card you can get that software easly on internet.
I need driver for saa7130 tv card
This particular device is tricky as Philips does not have drivers on their website, however there is a way to get this up and running.
First thing you are going to do is download two zipped folders, each containing the software that you will need. The first driver package is located here (unzip but do not install).
Second you will download the software package, located here (but do not unzip or install yet install).
Third, uninstall the TV tuner card if is showing up in Device Manager. You can get to Device manager by right clicking on My Computer and selecting Manage. In the left side click Device Manager. When all the devices are shown, right-click on the TV tuner card and click uninstall. Also, because the TV tuner card may be hooked up and no drivers are installed, you may see an "unknown device". Uninstall the "unknown device". Now run the installation/setup program from the first download and follow the step by step instructions.
After setup has finished installing the drivers, go ahead and restart your computer. After you have logged back into your computer, your operating system will recognize the TV tuner and may prompt you for the driver files via the Found New Hardware wizard. When prompted for a driver, browse to the first folder that you downloaded and select the driver file. Now that your computer has recognized and successfully installed the hardware, you will unzip and run the setup file from the second folder you downloaded. This is the software application that will use to interact with your new tuner card.
3helpful
I need installation cd for philips saa7130 tv tuner. where do i go get one?
PLEASE TELL ME NOW WHAT IS THE WAY OF DOWNLOAD OF FREE TV TUNER DRIVER.THE MODLE NO. IS TNF9935-B/IFF.
btwincap.sourceforge.net/
www.iulabs.com/drv/index.shtml
deinterlace.sourceforge.net/downloads.htm
OK, your card is a bog standard BT8*8 chipset, these are very common, and good cards, the top link are drivers for your TV card, install, below is another version should you prefer them, do some reading about the two. now the last link, is for the BEST TV card tuning software in the world, use this to run you TV card. 3d2f.com/tags/tv/tuner/software/bt878/ -
http://www.google.co.nz/search?aq=f&sourceid=chrome&ie=UTF-8&q=bt878+software
How do i turn tv tuner on
You must run the software that is what "Turns it on" the software once running enables the card. Then you can use it. get Amcap, thats a DirectX program that works on any TV card. As long as the driver is installed. As said you must also have the correct "Driver" for this card to work as well.
3helpful
25helpful
3answers
I need the software driver for my NEC TV CARD, MITAC P/N 531707310004, DATE 0504. TUNER TSEJ1-203A ALPS JAPAN - B400L4I
I need the software driver for my NEC TV CARD, MITAC P/N 531707.... DATE 0506 - G1BDA B6
Top Philips Televison & Video Experts
matt martin
matt martin
Grand Canyon Tech
Grand Canyon Tech
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
