SOURCE: 1999 f 350 diesel fuel filter location
It is on the very top of the engine. it is a black round plastic cover
SOURCE: 1998 honda passport themostat location ?
It's on the top front of your engine inside a rounded housing. Follow the top radiator hose - the thing it clamps to is the thermostat housing. I think it's held on by three bolts - two top and one bottom.
SOURCE: Brake Fluid Sensor
I believe it is a float in the master cylinder. If it's on, check your barke fluid level. Add if needed.
The reason for low fluid is that the front disc brakes are wearing down causing the brake caliper to move out which lowers the fluid level in the reservoir. So, also check your front brakes for wear.
God luck.
Please rate as fixya if this solves your issue. Thanks
SOURCE: Fuel filter location 1999 dodge durango
the fuel filter is located on the iner driver or pasenger side frame railing inbetween the front and rear doors. yes it has filter in the tank which is more comely know as the sock or straner. the filter will look like a metal canister .
SOURCE: Where is he fuel filter located on a 1999 Cadillac
Rear of the vehicle by the fuel tank...by the frame rail:
Disconnect the fuel feed pipe (1) at the in-line fuel filter and return pipe (2) near the in-line fuel filter
Squeeze the plastic tabs of male end connector of fuel filter
