There can be many ways to Unlock your phone.As far as i know unlocking by codes is the simple and safe way.You will need the unique MEP Code for your Blackberry and to get it you can use a website with service for Blackberry unlocking .so you can use a website to Unlock your Blackberry online instantly - OR local mobile shop .they are mostly using cables to unlock it and the price is higher then on unlocking websites but the result is the same: SIM free Blackberry.
You can get your mobile unlocked here
http://www.prounlocking.com/blackberry-8520-curve/rs8wp9/ at very low cost which gives you best solution...
You only have one option left to unlock blackberry curve if your mep counter attempt to 0, in this case blackberry unlock code will not affected anymore. You must doing cable unlocking process, this method will force your blackberry unlocked and you can do that at mobile repair shop.
Hi, first try an reset it before you unlock.
There are three main types of Reset that apply to the Blackberry. These
are listed in order below. Instructions for Blackberry Pearl are
slightly different - see bottom section of the Tip.
1) Soft Reset - simply press the ALT+RIGHT SHIFT(CAP)+DELETE keys.
This
reset stops all applications that are running on the Blackberry and
will help if you are having problems connecting the device to computer.
This reset will not erase any information from your device.
2) Double Soft Reset - this reset is almost equivalent to a full hard reset. First perform a Soft Reset as outlined in Step 1.
As soon as the screen is no longer black - repeat the steps once again exactly as before.
This
takes you to another screen showing an hour glass. Allow the device to
reset. This helps if the device has suffered a more serious error. Be
aware you may loose some information from your device. A backup is
advised prior to proceeding if at all possible.
3) Hard Reset -
this is the full blown reset and will fully reset the device to help
resolve critical errors with software or hardware. Again back up
important information before proceeding if possible.
Note:
For RIM models 850, 857, 950, or 957, you must insert the end of a
paperclip or similar blunt object into a small recessed hole on the back
of the unit and depress the switch inside. The device will reboot and
be hard reset.
Other Models: With the device turned on - remove the battery for 30 seconds or more. Now replace the battery. The device will reboot and be hard reset.
Blackberry Pearl:
To reset to factory defaults enter 'Options' from the main menu. Scroll
to Security Options and press the trackball. Choose 'General Settings'.
Press
the left soft key, then scroll to "Wipe Handheld" with the trackball
and press the trackball. To initiate the factory reset, your phones
security code may be required in order for the process to complete. Your
phone will now be restored to its original settings on leaving the
factory.
A hard reset can be achieved with the Pearl in the same way as outlined at Step 3 by removing the battery.
Be
aware that resets such as these may erase data, such as contacts, ring
tones, pictures, text messages and stored Internet files and emails.
Make sure to back up important information beforehand if at all
possible. You can obtain software to back up the device to your computer
directly from Blackberry right here.
the truth is that you can unlock the phone ,but you can't unlock all phone for free.
The payment sites are very cheap you could try it out and see.
You can the link below to unlock .
Note: unlock is not free, You will be charged to get your unlock code.
The only way by which you can get the unlock code for free is by calling your service provider
and requesting for your unlock code.
If you service provider refuses to give it to you, then there is no other place where you can
get a free unlock code.
Visit the link below if you are interested in buying the unlock code:
(mobileunlocked.com/mobile_unlocking.php)
Good luck.
Http://bbs.x-mobila.ru/index.php
Hi
u can get blackberry curve unlock code from this web http://gsmblackberryunlockcode.com this is very good web I had also take code for my blackberry fromthis because it can provide u code also following instruction forapplying code on your mobile & also in cheapest price after this u will be able to use anysim card on your mobile & can use mobile in any country of the world
thanks
Hi
yor is being locked don't tense because u can get blackberry curve unlock code from this web http://blackberryimeiunlockcode.com
it can provide u code + following instruction for applying code on your mobile& also in cheapest price after this u will be able to use any sim card onyour phone in any region of the world
thanks
You can unlock any blackberry from any network & after unlocking you can use with any GSM provider around the world by just entering one time unlock code which is comes from server based on IMEI & unique code for every set.
Unlock 3-Hutchison Blackberry
Unlock Airtel Blackberry
Unlock AT&T Blackberry
Unlock Bell Blackberry
Unlock Cingular Blackberry
Unlock Claro Blackberry
Unlock Comcel Blackberry
Unlock Cable & Wireless Blackberry
Unlock Digicel Blackberry
Unlock Etisalat Blackberry
Unlock Fido Blackberry
Unlock Globalstar Blackberry
Unlock Movistar Blackberry
Unlock O2 Blackberry
Unlock Orange Blackberry
Unlock Rogers Blackberry
Unlock Sprint Blackberry
Unlock T-Mobile Blackberry
Unlock Telcel Blackberry
Unlock Tele2 Blackberry
Unlock Telus Blackberry
Unlock Verizon Blackberry
Unlock Virgin Blackberry
Unlock Vodafone Blackberry
Unlock 9900 Blackberry
Unlock 9700 Bold Blackberry
Unlock 9650 Blackberry
Unlock 9630 Tour Blackberry
Unlock 9600 Blackberry
Unlock 9550 Storm2 Blackberry
Unlock 9530 Storm Blackberry
Unlock 9520 Blackberry
Unlock 9500 Blackberry
Unlock 9300 Blackberry
Unlock 9100 Blackberry
Unlock 9000 Bold Blackberry
Unlock 8900 Curve Blackberry
Unlock 8830 Blackberry
Unlock 8820 Blackberry
Unlock 8810 Blackberry
Unlock 8800 Blackberry
Unlock 8700 Blackberry
Unlock 8520 Blackberry
Unlock 8500 Blackberry
Unlock 8350 Blackberry
Unlock 8330 Curve Blackberry
Unlock 8320 Curve Blackberry
Unlock 8310 Blackberry
Unlock 8300 Blackberry
Unlock 8230 Blackberry
Unlock 8220 Blackberry
Unlock 8120 Pearl Blackberry
Unlock 8110 Blackberry
Unlock 8100 Blackberry
Unlock Gemini Blackberry
Unlock Javelin Blackberry
Unlock Niagara Blackberry
Unlock Thunder Blackberry
Unlock Torch 9800 Blackberry
SOURCE: I forgot my password for
You have to reset your mobile..This can be done by codes..I found the security unlocking service at Prounlocking.com .Through this you can reset your mobile easily..
SOURCE: My Blackberry 8520 Curve is
You can unlock your Blackberry CURVE 8520 after finish 10 attemts by cable process. go local mobile repair shop. after this process your Blackberry Unlock .No need to Mep code for your Blackberry . i hope this will help you:)
No one can give you unlock code for free. and dont try to enter unlock code. because it will block your blackberry. if you want to unlock your blackberry only use trusted sites. order your Blackberry 8520 curve unlock code herehttp://blackberrymep.com/unlock-blackber... this site charge very reasonable price.
