You can Unlock your Blackberry 8520 Curve with imei unlock code. it is very simple and eaisiat way to unlock your Blackberry. get your Rogers Blackberry Imei Unlock Code . and use any gsm sim card.
i hope this will help you .
Do not know about Rogers Blackberry 8520 free unlock code but you can get unlock code at cheapest rate by this Blackberry Curve 8520 unlock code provider.
Thanks
Get instant unlock code for BlackBerry only $1.50 / 99p / 1.25 euro @ www.bbcodes.co.uk - cheapest and fastest BlackBerry Unlocking Service in the world!
Blackberry can be unlock eaisly with remote unlocking codes. you can get this Blackberry imei unlock code from your network provider or get from third party,
both are safe way to Unlock your BlackBerry curve 8520 . when you go to online you can find so many sites of Blackberry imei Unlock Code. they will charge little amount for your Blackberry Unlocking Codes. i hope this will help you:)
Best of Luck.
It's simple to unlock the Phone from the Network Lock,you can get the Unlock code from the site
Wickedunlock.com/blackberry-8520-curve/rs11wp9/ and follow the instructions below and unlock it step by step:
Blackberry 8520 Curve Unlocking InstructionsWarning :
Do not enter any wrong unlock codes on your Blackberry 8520 Curve
mobile phones. If you enter over a certain amount of wrong unlock codes
on your Blackberry 8520 Curve mobile phone, your phone may get hard
locked and sometimes become unusable.
1 - Switch ON your Blackberry 8520 Curve with your current network/service provider's SIM card.
2 - Using the menu go to Settings Menu -> SIM card and press select.
3 - While holding the SHIFT key, type mepd.(NOTE: You may not see any text appear on the screen while typing mepd)
4 - You should now see the five locking categories listed.
5 - While holding the SHIFT KEY, type mep2.(NOTE: You may not see any text appear on the screen while typing mep2).
6 - Release the shift key.
7 - You will now be prompted to enter the Network MEP code. (it will also state how many attempts left)
8 - Enter the Unlock Code.
9 - Enter Return/Enter.
10 - The Blackberry 8520 Curve should then be unlocked.
