1999 kawasaki ZX-6R Ninja Logo
Posted on Aug 11, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
HOW TO REMOVE ENGINE FROM 1999 KAWASAKI ZX6 - 1999 kawasaki ZX-6R Ninja
Anonymous
Level 3:
  • Master 921 Answers
  • Posted on Aug 11, 2010
Anonymous
Master
Level 3:
Answers
921
Questions
Helped
332768
Points
2542
Drain all fluids first..then chain .then remove gas tank then rent a engine hoist and wrap chain around frame main structure near front of bike take off exhaust pipes and then get a car hydraulic jack stand and a small rectangular piece of wood and slip it underneath the engine to relieve pressure on the main engine mounts, pull out bolts, raise engine hoist a little then drop the car jack oh i forgot remove all your throttle, clutch cable first and fuel main line.
2 Related Answers
tombones
  • 3567 Answers
  • Posted on Aug 15, 2009
SOURCE: How do you set the timing on a 1995 kawasaki zx6?
Timing chain replacement is a bit complex for a beginner. I don't recommend it. However, I would suggest the best way is to have a service manual at hand. Go to this site and you can download a free PDF service manual.www.carlsalter.com/motorcycle-manuals.asp
The list of manuals may take 10 to 15 seconds to come up. The 2005 manual (4th from the bottom), is 11MB.
Also, go to the site below where you can see a parts diagram for your specific bike. You will select the actual brand, year, model, etc., once you go to the site. Part numbers and prices are also shown. You can order parts from this site. In the event no price is shown on a particular part and/or the notation "Not Available" is in the description, the part is not in stock. www.babbittsonline.com/pages/parts/viewbybrandand/parts.aspx
Can I get a “very helpful” rating on this answer?
raj somaiya
  • 5370 Answers
  • Posted on May 22, 2011
SOURCE: Kawasaki ZX6 1999, unable to remove forks to
Click the link below and follow the procedure:--- http://technoanswers.blogspot.com/2011/05/how-to-remove-standard-forks-on.html ------------ There is procedure for replacing fork seals and disassembly instructions .--------- This should help.Thanks.Helpmech.
Kawasaki ZZR600. Does anyone know the correct torque settings for the clutch spring bolts? thanks, Greg
Question edited for clarity.
Question moved to model category.
ZZRrocket · #8 · Mar 1, 2006
Just got off the phone with my service manager at my local Kawasaki dealership. "She" looked up the torque wrench setting for the clutch spring bolts. Its the same as a 2000-2002 ZX6R and 2005-2006 ZZR600.
Torque- Clutch Spring Bolts: 8.8 N-m (0.90 kgf-m, 78 in-lb)
Service Manual
http://zx6.us/docs/Haynes%20ZX600D-E%20-Service%20Manual.pdf
Kawasaki ZX600 (ZZ-R600 & Ninja ZX-6) Service and Repair ...zx6.ushttp://zx6.us > Haynes ZX600D-E -Service Manual PDF. A book in the Haynes Service and Repair Manual Series. All rights reserved. ...
Kawasaki. The Green Meanies by Julian Ryder. Kawasaki Heavy Industries. 243 pages
Whats the firing order for a 1990 Kawasaki 600 zx ninja.
The ZX6, as with most four-cylinder motorcycle engines, is mounted transversely in the frame. When sitting on the bike, the cylinders are numbered 1-2-3-4 left to right.
Firing Order: the firing order is 1-2-4-3. There is no distributor for the engine, as ignition is controlled electronically.
Extra Ignition Information: there are only two ignition coils for this engine. Each coil has two spark plug wires. One coil fires cylinders 1 and 4. The other fires cylinders 2 and 3
Lost key for gas tank filler,
10mm drill bit drill the key hole, and then unscrew the lock from under neath after taking cap off.
5helpful
WHAT IS THE FIRING ORDER FOR KAWASAKI ZX600R
Extra Ignition Information: there are only two ignition coils for this engine. Each coil has two spark plug wires. One coil fires cylinders 1 and 4. The other fires cylinders 2 and 3.
Addtional details in this link: images/4/45/ZX600E13.PDF
hope this helps (remember to rating this free answer).
How many times should i turn the fuel to air screw out on a 1999 zx6. i have it out 2 and a half turns is that the best?
Standard is 1 & 1/2 turns out- Using a infra red Gas analyser, I found they would run the best between 2 & 2 & 1/2 turns out.try to search for the setting with the smoothest idle. So yes- you seem to have it set correctly.
Regards Andrew Porrelli
Crank won't crank
while installing the new part you may made some mistake. take it to the kawasaki worksop and check the new part with an expert
1helpful
2answers
What year engines will fit in my 1996 ZX6 frame?
1995-1997 after this the mountings were changed
1helpful
What engine will fit in a 1986 ninja?
Get a different engine just like the one you had. Google " motorcycle salvage Kawasaki " and you can probably find the engine you need there. The best thing is now you have a whole lot of spare parts > the old engine.
Please rate this answer. Thanks Andre!
Top kawasaki Experts
Arnie Burke
Arnie Burke
Sean Wright
Sean Wright
Bob G
Are you a kawasaki Expert? Answer questions, earn points and help others
