KitchenAid KHMC107BT Convection/Microwave Oven Logo
Posted on Jul 25, 2010
How to make a choclate cake in IFB convection+micro model 23SC1
Anonymous
Level 1:
New Friend:
  • Contributor 2 Answers
  • Posted on Jan 21, 2013
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
740
Points
How to make chocolate cake in microwave
3 Related Answers
Anonymous
  • 36 Answers
  • Posted on Jan 07, 2010
SOURCE: cooking temp to bake cake inn convection mode samsung model
Hi I guess you are cooking usng the combination setting? if so The cake will be hard due to increased microwave energy, I would suggest reducing the microwave energy on the Samsung unit when using the combination setting.
Hope this helps
Anonymous
  • 35 Answers
  • Posted on Mar 25, 2010
SOURCE: i want to make a cake with my new ifb convection
Maybe try a cookbook? ;-)
Seriously, the best way to make cakes in a microwave oven is to use the convection setting only.
Your user manual will tell you how to select this open.
Anonymous
  • 15 Answers
  • Posted on Feb 28, 2011
SOURCE: I hv got a ifb
You should be using convection mode first of all. It's not clear from your post if you are. Also looks like you're oven is baking at higher temperature than it says. Try 170 degrees for 13-14 mins instead.
2answers
I have an IFB microwave 30sc2 on its touch pannel the stop/reset button is not working all other buttons r working
IFB microwave ( which i have 30sc2) are directly imported from china, i find in many friends who bought this device are having a lot of problems, the microwave have major defect in the thin flim front membrane panel and the pcb board, after spending a 5 times with various issue the cost came to Rs 8700.00 not forgetting the repair done within warranty period, luckily i found a person who modified the front panel , replacing with MICRO SWITCH, the pcb was also modified relay, latter rotary switch front panel of Samsung and pcb was installed in place of old, now it had solved the problem, now use it only in convection and grill for nutrition reason. would like to help any one who has this problem.
1helpful
I hv got a ifb microwave oven 23sci with grill , i have tried baking cakes many time and every time it gets burnt. The sides get baked and the central zone is unbaked. MY method is , I take a glass utensil...
2helpful
I want to make a cake with my new ifb convection micrcowave...i am new to this.. plz assist me?!!!!!
Cooking temp to bake cake inn convection mode samsung model
Hope this helps
I have a siemens combi micro oven, which is the best way to cook a christmas cake and at what temp
with the convection part at 325 deg, for 1 hour or less depending on the cake size..have fun cooking..
2answers
Setting of a microwave
You can download the owner's manual If you will copy and pastew the entire URL into your browser's address bar:
http://org.downloadcenter.samsung.com/downloadfile/ContentsFile.aspx?CDSite=us&CttFileID=29957&CDCttType=UM&ModelType=C&ModelName=MT1066SB&VPath=UM/200303/20030318134829578_DE68-02235A.pdf
This will be the perfect solution to your problem.
We're happy to help and we appreciate your thoughtful rating of our answer.
Top KitchenAid Microwave Ovens Experts
ZJ Limited
ZJ Limited
john h
Are you a KitchenAid Microwave Oven Expert? Answer questions, earn points and help others
