20 Most Recent KitchenAid KEMC377K Convection / Microwave Oven Questions & Answers
http://www.applianceaid.com/repair-help.html
 for complete step by step guide for ur microvave parts and fitting procedure
KitchenAid... | Answered on Sep 09, 2017
The installation guide for KEMS377D is from Whirlpool for KBMC140. Follow the instruction how to remove the microwave from the cabinet.
KitchenAid... | Answered on Oct 08, 2014
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
dhjjd
KitchenAid... | Answered on Dec 16, 2013
My over the range microwave had a loose door, it sagged when it was open but you could lift it to close. Called repair person he said no it could not be fixed. You could see the bottom hinge was loose and slipping. I loosened 3 screws that holds the bottom on the microwave -you have to do this to change the light bulb also. The bottom hinge on the door was loose there was a hole there, so took a screw and nut to hold the hinge in place..I am a 70+year old woman-if I can you can.
KitchenAid... | Answered on Apr 16, 2012
There are electrolytic filter capacitors on the control board which, due to age, can weaken, causing some bizarre results.
We've repaired several of these boards successfully, upgrading the capacitors and relays at the same time. It runs $39.95 and comes with a one-year guarantee.
They're the same as the Whirlpool RM286- and RM288-type models.
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
You can also find helpful exploded views here.
KitchenAid... | Answered on Oct 18, 2011
Having noise means some obstruction near the rotating tray or its motor need some lubricant. Has for no cook but control seems working, the magnetron and its fuses is the culprit because it doesn't anymore produce heat to cook food.
I hope that advice help you.
KitchenAid... | Answered on Mar 31, 2011
kitchenaid expert here
Welcome to fixya
Hello
I have a solution for this
Press Ok, Accept or replay so we may get started
Your pre-solution is coming up shortly
PLEASE REPLY OR LEAVE COMMENT TO CONFIRM YOU RECEIVED THIS EMAIL
My name is Bruce
KitchenAid... | Answered on Jan 18, 2011
This is a very complex repair, and should only be done by a technician that has worked on these a lot. The heating problem can be wiring, magnetron, safety thermostats, high voltage diode, transformer, capacitor, or control board. Out of all the brands and models we work on this is one of the toughest to work on because of the amount of labor you have to put into it, to get into the unit to diagnose this type of problem. I would recommend that you use one of whirlpools warrantee companies, as they will probably have the most experience with this model. Good Luck, Appliance Specialists.
KitchenAid... | Answered on Dec 09, 2010
If the switches are good (test & order info here), and it's a Kitchenaid / Whirlpool of recent design (by L.G.) then they have more than one fuse inside.
There will be a fuse associated with the door circuit which will cause this problem, but not render the oven "dead".
There should be a "mini-manual" (tech sheet) hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting, testing, and locating components.
If you don't find your mini-manual, or if you want to look at it before removing the controller, you can download it here (just enter your model number).
You can find links to helpful exploded view diagrams and part ordering help here.
I recommend that you bookmark that link to your favorites.We're happy to help you with free advice and we'd appreciate your thoughtful rating of our answer.
KitchenAid... | Answered on May 16, 2010
You can download owner's manuals and installation instructions for several brands (including Amana, Jenn-Air, Kitchenaid, Litton, Maytag, Roper, Tappan, Thermador and Whirlpool) here.
KitchenAid... | Answered on Dec 26, 2009
That model number does not look right. Please check the tag on or in the unit again.
You can find helpful exploded view diagrams and order parts here.
If you don't find yours, or if you want to look at it without disassembling the oven, you should be able to download it here.
The door springs must be replaced in pairs to keep the wear even.
KitchenAid... | Answered on Dec 13, 2009
hi! humming are cause of many things, either you have a defective magnetron, leaky capacitor, or the hv transformer. but most likely the magnetron is the culprit.
KitchenAid... | Answered on Sep 15, 2009
KitchenAid KEMC377K Convection / Microwave Oven Logo
52 questions posted
Top KitchenAid Microwave Ovens Experts
William Miller
William Miller
Marvin
Marvin
Michael Thomas
Michael Thomas
Are you a KitchenAid Microwave Oven Expert? Answer questions, earn points and help others
View Most Popular
  • KitchenAid Microwave Ovens
Most Popular Question
loose microwave door
  • Microwave Ovens
