WELL YOU NEED A SPARK PLUG BOOT PULLER.TO REMOVE PLUG BOOT.TO BE ON THE SAFE SIDE BUY NEW PLUGS WIRES.BECAUSE WHEN YOU REMOVE SPARK PLUG BOOT THE INSIDE CONNECTOR GOING TO STAY WITH SPARK PLUG TERMINAL AND THE INSIDE SECONDARY WIRE WILL BREAK AWAY FROM THE INSIDE CONNECTOR THAT FITS OVER SPARK PLUG TERMINAL.YOU WILL NEED NEW SPARK PLUG WIRES THIS INCIDENT HAPPEN TO ME AND I HAD ONE VECHICLE AT THE TIME IT HAPPEN.
Well its a lil tricky but the best thing to do is to rotate the boot to the left about 180 degrees then let it go then to the right about 180 degrees do this till it turns free of the plug then rock and pull on it. any attempt to pull on it before the boot frees off of the plug will surely break it
I find if you take the end off the coil first it makes it easier to get the spark plug end off for some reason. It pulls off straight but some twisting to break the seal does help.
I'm not sure, but I believe they just pull straight off. Try wiggling back and forth as your pull it off. But, you do need to pull it hard to get it to come off, it will not just slide off.
