I just got a Mitsubishi 60719 60 in projection TV and after a few days of use it has a pivture issue. After being on for a few hours, the picture started to warp and flicker. Basically, the picture starts to shrink towards the center of the screen and the screen shakes a little. I thought I smelt something burning in the back but I opened up the back and cant see anything discolored.
My thoughts are either a lose connection or a bad capacitor. Even though the screen flickers the colors seem to be lined up perfectly, it as if all of the lamps are receiving surges at once.
Any thoughts on this would be great, thanks.
-Greg
SOURCE: need anwsers asap! Mitsubishi VS-60719 60 in
Can you psot a picture of what the lines look like and I will try and help you out with it. Please reply to this same post each time. Thanks
SOURCE: Mitsubishi VS-60719 60in. Have horizonial lines that flicker and a problem with the convergence
we appreciate your patience - good luck on your new TV
SOURCE: 11-year old Mitsubishi VS-6043 picture flickers and bends
check for cold solder joints on the yoke connector located behind the speaker grill and mounted on the crts. You may also want to check for cold solder on the vertical output i.c.
SOURCE: I have a 2000 Mitsubishi VS 60707 60
the DM board is failing and it is no longer avail sorry
