Usually the CV Joint pops when worn making turns so check that out. The bad one will pop when only putting a load on it. Here an example, say the left side is bad and you make a right turn. It will not make the popping noise only unless both sides are bad
Cv joints on front axel dry need grease boot broke
Could be hitting the shield or out of alignment or any number of suspension components or CV boot going. Bring it into someplace that does free suspension inspections. Tires Plus used to do them around here. Google it if you need to.
Is the noise while turning when driving or can you create the noise just sitting and turning the wheel?
