After 5 months of cool operation ,usb ports can not recognised from win xp
(i have yellow flag in control panel) not any other usb port via pci card ..
1. It may be due to some driver conflict.
2. I suggest you to check the ports for any metal/materials being got stuck into which may cause the power conflict. disconnect all the hardware connected to all the uSB ports in your system.
3. Right click on the yellow icon show in the device manager control panel and select uninstall option against all the yellow ions.
4. Restart your machine and this time your USB port should be working fine.
I hope this is helpful to you
Please rate the solution provided.
Thanks
Right click on the yellow flag and uninstall the corrupt driver. Restart the computer, plug a USB device in and it should be resolved. If not post back.
Regards.
Shut down your computer completely, unplug the power cord from the back
for at least a minute (this drains the power from everything). Make sure all devices are unplugged like printers etc.
Then power it back up.
This seems to be a common problem with Gigabyte motherboard so your not on your own with this problem.
The only thing that i can suggest now is update the BIOS and download the chipset driver from Gigabyte support website.
Also try a Microsoft update, that may resolve the problem for you.
Let me know how you get on.
click start control panel administrive tools computer management device manager scroll down universal serial bus controllers you should see a yellow question mark?
right click to reinstall drivers
if you can see your usb drive but its not working
ports(com&lpt)right click update driver if this fails to fix the problem
click start control panel administrive tools computer management disk management right click on your drive select properties click tools you should see click check now click start two boxes automatically fix files and scan for and attempt recovery of bad sectors place then a tick in both boxes then select check now start or you might tick one box then return after its finished the first repair then return and tick the second box you should not do anything while the chkdsk utility is in progress any input may damage this drive
hope it helps
i did it a lot of times,it is not worked
i still have yellow flag in device manager
it is not worked
