Sony VAIO PCV-RX753 PC Desktop Logo
Posted on Jun 23, 2010
When turning on the computer sony vaio pcv-rx753
When turning on the computer, it goes to hibernation.how do you fix that?
Anonymous
Level 1:
New Friend:
  • Contributor 26 Answers
  • Posted on Jun 23, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
26
Questions
0
Helped
10442
Points
96
IF YOU DO NOT USE THE HIBERNATION OPTION THEN YOU CAN GO AHEAD AND DISABLE IT
NOTE: HIBERNATION OPTION CONSUMES A LOT OF SPACE ON YOUR COMPUTER.IT MIGHT HAPEEN THE COMPUTER DOES NOT HAVE FREE SPACE SO THAT IS WHY IT IS GOING TO HIBERNATION.
PLEASE FOLLOW THIS LINK AND THEN CHECK WHAT IS YOUR EXACT PROBLEM:http://support.microsoft.com/kb/929658
MY EXPERIENCE:If you happen to use a computer with more than 1GB of RAM coupled with Windows XP SP2, then you will have trouble putting your computer to hibernation. You may get this message, “Insufficient System Resources Exist to Complete the API”. When you experience this problem, the hibernate feature is not available on the computer until you restart the computer. I was facing this problem because my computer has got 2GB of RAM and putting it to hibernation was causing me trouble. Well you need not worry about it any more as Microsoft has issued a patch for this problem
Computer wont turn on after lightening strike and i cant find the reset button on the inside of my sony vaio pcv-rx753. i have reset it twice in the past but now i must be blind. any ideas?
Those internal things are CMOS reset. that won't help you. but try this. Unplug the computer for a while, while cylcing the power button, then plug it back in. The power supply has an internal circut breaker and this will hold open as long as the power is still applied. once drained it will close and if it is still good you should be able to start it.
I turned on the computer to allow it to download
not as far as im aware try removing the 24pin connector from mobo and replacing it then reset the bios jumper by jumping it from norm to reset then turn on pc for a second turn pc off and jump it back power up pc and this should fix issue
1helpful
2answers
Recovery for the Sony Vaio pcv-rx753
if it came with the restore CD's then thats exactly what they were for. You need them. if you have lost them you can order new ones from the manufacture.
VAIO PCV-W510G Keyboar & mouse wont work
Hi torr3s_t,
Here is a web site where you can download your computers manual: http://esupport.sony.com/US/perl/model-documents.pl?mdl=PCVW510Ga . I would copy and paste the web site.
Here is Sony's support Number for computers: 239-768-7545 Monday- Saturday 11:00 AM-8:00 PM ET
Hope this helps,
GaWebSpinner
STARTING PROBLEM
its a problem with your hard drive controller. try plugging the hard drive into the secondary ide port.
2answers
Cann't shut down properly
If you are trying to shut down with the camera still connected!!??GOTO the bottom right of screen and ""safely remove hardware"" see if the system will shut down.....sometimes a hardware driver does not want to shut down so you must turn it off and plug it in again when you start windows again....
Vaio Sony wont go to the users acount
Hold button down for 5 seconds to switch off. The switch on and press F8 and choose safe mode boot. If it boots try a repair option or system restore to a previous working state
Sytem recovery disc 1
1) Try to make a copy doing an "IMAGE DISK"
2) If you couldn't:
You can download all your drivers for your desktop computer
without a Restore Disk. (But You will need a copy of OS)
http://esupport.sony.com/US/perl/swu-list.pl?mdl=PCVRX753&LOC=3
2answers
Low disk space on C: drive
Try getting rid of all temporary files and programs you don't need. From My PC right click on C drive then click on 'disk cleanup'.
Top Sony Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
k24674
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
